01-13-2024, 06:37 PM | #1 |
Where do I install flush T?
Hey folks, Quick question, I bought a peak radiator flush kit and it says to install the flush tea on the in-line hose going to the block and not the one that goes to the water pump… The issue is one of my heater hoses goes directly to the radiator the other one goes to the water pump and then the water pump has a bypass hose that goes straight to the engine… So where exactly do I hook up the flush tea so I can do a flush on my engine?
Cesar Diaz 1972 C10 Big Block 402 Cheyenne Last edited by LockDoc; 01-14-2024 at 05:12 PM. Reason: Wrote wrong thing |
01-13-2024, 06:55 PM | #2 |
Re: Where donI install flush T?
Do you have a pic of your confusement of hoses?
01-13-2024, 09:59 PM | #3 |
Junior Member
Your heater core should have a hose from the intake manifold, and the return hose should be to the water pump or the radiator. You would place the tee in the hose to manifold. That would flush your engine. If you have a plug in the manifold, you could replace it with an NPT nipple and connect your flush hose to that. You'll probably want to remove the engine plugs on either side of the block above the oil pan.
01-14-2024, 12:37 AM | #4 |
Put it in the hose going to the bottom of the heater core.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
01-14-2024, 11:35 AM | #5 |
Correct. The block will flush no matter where you put it. It's the heater core and radiator that the flush is mostly about. Smaller passages in both cores are the number 1 clog areas, so pressure matters there. The radiator can be flushed by itself or even removed for a professional flush, cleaning, or rodding
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-15-2024 at 08:25 AM. |
01-14-2024, 03:49 PM | #6 |
425hp409
Everything should be reverse flushed.
To flush the heater core you would put the flush tee in the hose at the top of the heater core. To flush the radiator by itself, flush from the outlet to the inlet. To flush the block, flush from the intake to the water pump.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
