12-14-2016, 10:40 PM | #1 |
HEI no spark during crank problem
seems ive read many threads on this issue yet no definite answer has been put out. 3 days ago i got finished putting an RV 454/700r4 in my suburban. Unable to get her fired up. The keyed on 12v wire that goes to the bat + terminal has power. ive tried so far
- connect to 12v junction block - connect directly to the battery - connecting directly to the alternator. Still nothing. HEI has new cap, coil, rotor. Ignition module tested good at autozone. My next move is to run wire directly from the bat + to the starter's R terminal as if this was a points-to-HEI conversion. I just dont see how something do simple can be a PAIN in the ass. any suggestions would be great.
*UNDER CONSTRUCTION* '80 Suburban C20 (C6P) (Silverado) - '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior |
12-15-2016, 03:41 AM | #2 |
Re: HEI no spark during crank problem
Are you getting any spark at the plugs?
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
12-15-2016, 05:39 AM | #3 |
No, not gettin any spark at the plugs
12-15-2016, 08:57 AM | #4 |
Sometimes a module can be bad and still test out good. If 2 good modules don't work then I would start looking for a broken wire in there. I guess pick ups can go bad but it never happened to me except for the broken wire.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
12-15-2016, 02:14 PM | #5 |
Did you remember to put the metal ground strap back in when you replaced the coil?
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
12-15-2016, 08:28 PM | #6 |
yes i remembered that. i am now have 10 gauge wire from starter R terminal spliced into keyed on 12v (goes to bat + on HEI) wire that comes out the firewall and still no spark. im guessing ignition module is the next step
12-16-2016, 12:44 AM | #7 |
Did you verify that the keyed 12V feed is energized in the "Start" position as well as in "Run"?
I have had 12V with the key in the on or run position, but it dropped out in the start position because the two ignition (Run and Start) outputs were not jumpered together.
Keep your head up...and your stick on the ice. |
12-16-2016, 01:01 AM | #8 |
Did you check the original grounds from and to motor.......my 87 GMC runs power to form alt to battery and cable to starter but my buddy's 86 Chevy runs from alt to starter and battery to starter but not alt to battery......grounds intake to firewall, block to frame, battery to frame....
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
12-16-2016, 01:27 AM | #9 |
I would isolate the ign switch by running a 10ga from either the battery or alternator output direct to the + on the distributor, then crank it over. If you get spark then you've eliminated distributor (module, pickup, ground) and can then look at the ignition switch.
12-16-2016, 02:28 AM | #10 | |||
Ground is cable to engine block, bolted strap from rear driver side head to the firewall. smaller 12 gauge wire from cable to near the radiatiator support. Anything i should modify or add? Let me know, thanks
*UNDER CONSTRUCTION* '80 Suburban C20 (C6P) (Silverado) - '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior Last edited by 85raiderburban; 12-16-2016 at 02:48 AM. |
12-16-2016, 10:18 PM | #11 |
UPDATE: Got her runnin'! i changed the ignition control module and kept the starter R terminal attached and she fired up. More crap to to do to the truck before she road ready tho. Thanks again guys for all the help!
