Old 02-21-2018, 09:18 AM   #1
84 K30 496 engine swap...what all should I change?
I’ve had a 496 engine that Mark at Vortec Pro built for me back in 2010. It’s been sitting on my engine stand for about 4 years after pulling it out of another truck I have.
The truck it’s going in (84 K30 454) has a SM465 transmission, the previous truck (76 C35) was an automatic (TH400).
I was going to order some Hedman (ceramic coated) Hedders, motor mounts, transmission mounts, clutch kit.
Anything else I’m forgetting?
Any feedback or opinions are welcome...
Old 02-21-2018, 10:12 AM   #2
geezer#99
geezer#99's Avatar
Re: 84 K30 496 engine swap...what all should I change?
Pilot bearing.
New one would be good if you already got one.
Old 02-21-2018, 11:48 AM   #3
b454rat
Some type traction device and big tires!! I swapped a mild 454 in a truck I built and would smoke the tires off.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 02-21-2018, 03:11 PM   #4
Originally Posted by b454rat View Post
some type traction device and big tires!! I swapped a mild 454 in a truck i built and would smoke the tires off.
lol
Old 02-21-2018, 09:21 PM   #5
70K10Hunter
70K10Hunter's Avatar
I am going to assume that your 496 is an 8.1 liter engine?
I have heard and am asking does the engine block have mounts for the starter?
If it doesn't then you will have to find a bell housing with a mount built in.
I am asking as I'm also thinking I want to do the same.
70K10Hunter is offline   Reply With Quote
Old 02-22-2018, 12:28 AM   #6
Captainfab
60-66 Nut
Is the 496 externally balanced the same as a 454 is? Was the engine balanced when built with the flexplate installed? If so, changing the flexplate to a flywheel will somewhat disturb the balance of the engine.
Old 03-03-2018, 09:48 AM   #7
I’m mistaken; it’s a 468 build. A bit to many things going on and my simple mind doesn’t hold data like it used to
Old 03-03-2018, 09:53 AM   #8
Thanks Capt, as per the builder I think my task is to find a stock, un modified 454 flywheel for my project. Thank you for the question.
I only get to mess with my stuff occasionally, sometimes it’s months before I get back in the shop to tear stuff up
Old 03-03-2018, 02:14 PM   #9
kwmech
Seems like a huge waste of horsepower in front of a 465 manual trans. Not like you can speed shift that beast or keep it in the power band with the wide ratios. Of course the power band is subjective with the amount of torque
Old 03-03-2018, 05:19 PM   #10
It’s just a fun project is all. Didn’t need to make sense
