Old 07-18-2018, 08:07 AM   #1
GMC_Tom
8 Lug steel wheels
Hello everybody,
my name is Tom and I'm from Austria. Sorry for my bad english.
I bought a 1965 GMC truck 3/4 ton with a crazy colour
Currently I'm doing a frame off restoration.
My question is whether steel rims fit in 15" for 8 lugs. My favourites would be Cragar Black D Window Wheels with 10" width in the back and 8" width in front. The truck has drum brakes on all corners.
It's easier to get tires for 15" rims (275/60 and 245/60)
[IMG][/IMG]
GMC_Tom is offline   Reply With Quote
Old 07-18-2018, 12:12 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 8 Lug steel wheels
Hi Tom and welcome to the site. Cool truck, I am sure there are not a lot of them in Austria.
Most 8 lug (3/4 ton) trucks use a 16" wheel (originally it was likely 16.5" but those are rare today). With drums all around, it could be likely 15" wheels would fit.
Looking at Cragers website, I don't see any 15x8 in 8 lug, only 15x10. In 16" they have 7", 8" and 10" wide available. Not sure how easy it will be to find 15x8 8 lug. Might need to be custom/special ordered.
Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-19-2018, 01:19 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
I bought a 3/4 ton truck a while back and the previous owner put 16" wheels on it but the spare was an 8 lug 15" wheel. I might still have it and if I do can take a picture of it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Truck pictures: http://s49.photobucket.com/albums/f2.../The%20Trucks/
Chevy Fleetside is offline   Reply With Quote
Old 07-19-2018, 02:04 AM   #4
GMC_Tom
Thank you for your reply
On the Cragar website i also could not find the 15x8 in 8 lug but on the website of summit racing
https://www.summitracing.com/int/par...5880/overview/
Chevy Fleetside - a picture would be great
Old 07-19-2018, 06:34 AM   #5
PGSigns
PGSigns's Avatar
Before you do much shopping for wheels do some reading on what will fit. A 10" wheel may not go under the back. On my 66 I run 15X8 with 4 inches of back spacing and the 275 tires rub on the inside of the wheel well just a little at times. The truck is lowered 5" in the back. The wheel you posted has 4 1/2" of back spacing and I don't think you will get by with it. Many threads on here about wheel sizes and what will fit.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-20-2018, 03:13 AM   #6
GMC_Tom
I thought it is a 10" rim necessary for a 275 tire. I read half the night through the board
With the Backspace you are right. The only 8lug rim/possibility I see is the Bart Wheel Super Trucker (Backspace 3,5inch). Hope I'm right.
https://www.summitracing.com/dom/par...5808/overview/
Old 07-20-2018, 07:15 AM   #7
PGSigns
PGSigns's Avatar
Here is what you need to do to help figure out what you can get under the truck. Jack it up and remove the tire. put a straight edge on the wheel mounting flange and use a tape measure to get the distance to the inner and outer wheel well at where you think the tire may be when on the ground. This gives you an idea of the room you have and where the tire needs to be in relation to the housing end. That will tell you what back spacing and tire width you need. You can go on places like tire rack and look up sizes and brands of tire and see the diameter, section and tread width and the recomended rim size. The section width is the important one. The side of the tire is what will rub most the time. A tire and wheel combo that fits may rub with another manufactures tire of the same size due to a wider section width. Her is a link to a tool for checking what will fit. You can make one out of aluminium angle that will do the same thing and fit your 8 lug housing. Will save you lots of time and trouble getting a wheel and tire that will fit.
Jimmy
https://www.jegs.com/i/Percy's/7...iABEgIkofD_BwE
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Copyright ©2000 - 2018, vBulletin Solutions Inc.
