Old 11-13-2018, 01:44 AM   #1
Bob Q
Hydroboost or Master Cylinder?
On my dad's '84 K2500 diesel, we noticed the brake pedal is now bleeding off when the brake pedal is depressed. Other than that, the brakes seem fine. Do you think that sounds like the hydroboost is going out or the master cylinder?
Thanks!
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 11-13-2018, 02:27 AM   #2
mongocanfly
Re: Hydroboost or Master Cylinder?
the hydroboost wont cause the brakes to bleed down...the hydro just assists the pedal like a vacuum booster does... sound like the master
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 11-13-2018, 01:45 PM   #3
sweetk30
sweetk30's Avatar
and it will get stiffer if there is less boost from the hydroboost unit .
hydroboost units rarely go bad except for massive dirt in system or bad seal . otherwise they just work and work .
i just put one back in service that has sat for 10 years in my parts stash . still had the system closed with p/s pump/lines / box all hooked to it . but installed it and she is working .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 11-14-2018, 12:38 AM   #4
Bob Q
Thanks guys. I'll check it out.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
