Old 02-14-2020, 05:59 PM   #1
Dachshund
Brake Line Question
OK - crazy question here! Anyone know what type and how many of each of the little brass "blocks" for the brake lines I need? This is for a 4 wheel disc system, stock frame. Also, where to buy them. 1947 3600.... Any ideas would be appreciated!
Dachshund is offline   Reply With Quote
Old 02-14-2020, 09:27 PM   #2
mongocanfly
Re: Brake Line Question
You'll need one for every joint...I assume you mean the couplings...it all depends on how many pieces of tube you use and how you route it..you'll need a T for the rear axle and a T for the front ..unless you run 2 fronts from the prop valve...I got all mine at oreillys
Mine is all 3/16 for the fronts and 1/4 to the rear , and then splits into 3/16 at the axle
You'll need to determine what thread size you have..
Are you gonna try to do it all in one piece or use the premade sticks like the parts store sells?
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 02-14-2020, 11:02 PM   #3
mr48chev
mr48chev's Avatar
A few questions:
Are you using various lengths of brake line from the parts house with the fittings already on them? If that you need a Brake line union between every pair of fittings such as this one https://www.napaonline.com/en/p/BK_6...xoCXAgQAvD_BwE
Any parts house that has the brake line should have the fittings though.
Those should have the correct ends to go with the flare and the male thread fitting on the tubing.
You can buy the tubing in up to 60 inch pre made lengths so a 5 footer and a correct length shorter piece should get you to the spot where you connect the hose for the rear axle to the tube. That is a guess though as you may need a longer length if you have the master cylinder on the firewall.
You still need to measure out all of your runs including bends and zigs and zags and then see what is available that comes closet.
You will need a Tee on the axle and a Tee on the front brake lines to split the lines to go to each wheel.
On the other hand if you are making up your own lines with just the SAE inverted flares you just need the flare fittings and the Tees plus the hoses for the wheels and the axle.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 02-15-2020, 06:16 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
Just buy one of the Speedway brake builder kits. They come with all the pieces you might need.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 02-15-2020, 01:56 PM   #5
Dachshund
Ok, guys! I was talking about the "T" fittings that bolt to the frame...…
I was going to try to make my own lines, but am thinking about a "kit" now.....
Old 02-15-2020, 02:34 PM   #6
mr48chev
mr48chev's Avatar
Looking at those speedway kits you are spending a lot of money for extra pieces that you won't use. Some of them still require that you flare the tubing if that is an issue.
The only advantage is that if you aren't good at hunting parts and didn't save some of the pieces like the brass Tees some of the kits provide them.
Old 02-15-2020, 02:41 PM   #7
Dachshund
My lines and t fittings were SHOT! Have to start all over...
Old 02-15-2020, 03:06 PM   #8
mongocanfly
as far as Ts go youll need one for sure...that would be on the rear axle...
my rear axle T is 1/4 inlet and dual 3/16 outlets...
on the front
one truck I have, the prop valve mounte on the master cyl and goes down to a T on the frame for the front...1/4x3/16x3/16
the other truck the prop valve is mounted down on the frame and no Ts are needed for the front on it...
if your gonna make your own lines youll need a good brake line flare tool for the double reverse flares
Mongo...aka Greg
Old 02-15-2020, 08:25 PM   #9
skip99
skip99's Avatar
Inlinetube.com
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
