Old 07-02-2019, 11:24 PM   #1
Softpatch
Softpatch's Avatar
Just when you think your out (64 FS) 66 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=789027
Just when you think your out (64 FS) 66 FleetSide
Part II
After listening to members about my "66"/ 02 swap
I have decieded to go with
Option 2:
Just picked up this 91 Sportsvan "Custom"
with 60'000 miles on it For the 5.7 and 700R4 and bits
to go into the 1966 Fleetside
I'll keep you posted
Thanks for the feedback....Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 07-03-2019, 10:06 PM   #2
Softpatch
Softpatch's Avatar
Re: Just when you think your out (64 FS) 66 Fleetside
Thanks Mike
Old 07-31-2019, 11:07 PM   #3
Softpatch
Softpatch's Avatar
Big day
Pumped up the tire
Last Ride /Burnout on the sportsvan
pulled up to the shop
Nast bit of work It's out
.....Sp
Old 08-07-2019, 03:24 PM   #4
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Hahahaha, For some reason I just thought about Smokey and the Bandit..."Sombit$h" lol
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
If ever the Time should come, when vain & aspiring Men shall possess the highest Seats in Government, our Country will stand in Need of its experienced Patriots to prevent its Ruin.
gulfcoast66 is offline   Reply With Quote
Old 08-07-2019, 10:50 PM   #5
Softpatch
Softpatch's Avatar
Not what I was going for ...But now I see it Good one
Rust in piece Buford T justic.......Sp
Old 10-20-2019, 03:19 PM   #6
Softpatch
Softpatch's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=795140
Thanks to hatzie
Manual for 1991 G-30 5.7/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=700011
The Electrical Diagrams
(1991 ST-375-91-EDD GM KC Light Trick Wiring Manual)
...Sp
Old 10-20-2019, 03:49 PM   #7
Softpatch
Softpatch's Avatar
Update
Drive line in
Gas tnk mock up 10-17-19
In and Running 10-18-19
Wiring Phase
.....Sp
Old 10-20-2019, 03:55 PM   #8
SkinnyG
SkinnyG's Avatar
Do you have another method of hosting images other than Photobucket? I'd love to see your work. Photobucket is kicking me in the eyes right now.
Nostrildamus - 1961 Apache, now under the knife
The Crusty Chevy - 1977 Silverado, shortboxed & dropped, potato-potato.
The Fiendish Firefly - The ultimate engine swap: 5.7lbs in a 1lb bag
The Lethal Locost - Street legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-20-2019, 04:00 PM   #9
Softpatch
Softpatch's Avatar
.....Any recomendations ..??
My "work" is messy My goal is to piece together these two trucks and make it "Low budget build"
Old 10-20-2019, 04:09 PM   #10
Softpatch
Softpatch's Avatar
Test
Old 10-20-2019, 04:10 PM   #11
Softpatch
Softpatch's Avatar
Test 2
Old 10-20-2019, 06:33 PM   #12
SkinnyG
SkinnyG's Avatar
That works awesome! Thanks!
Old 11-15-2019, 11:41 AM   #13
Softpatch
Softpatch's Avatar
Temp fab motor mount ( looking back underneath )
Driver side ... passenger side
My only issue I believe the Engine angle not right.?
I will revisit this after I check off more goals
On the truck
.......... next mounting ECM
Continue Fab exhaust
Shift linkages
Another Restart
.......Sp
[attach]Name:  08525597-5EB8-4DEB-8825-D26A7F468088.jpg
Size:  55.9 KB[/attach]
Old 11-16-2019, 12:00 AM   #14
Captainfab
60-66 Nut
I don't understand why you aren't just using the original engine mount brackets as they are? Any small block will just drop in place with them.
Old 11-16-2019, 11:39 PM   #15
Softpatch
Softpatch's Avatar
The Last owner had a 454 in the truck and it looks like they Modified The Old six cylinder Mounts to fit the BBC .
Those mount I modified were the Mount that were in the truck
when I rescued it. (yard art) sitting under Pine tree's 10 + yrs didn't do it any good.
They didn't quite fit the 454 because they sat High (6 cylinder).?
those mount that came with the truck were chopped on the top of the mount because they look like they needed clearance
(hitting both Bottom side of the Exhaust manifold)
and The engine sat back so for They beat on the Firewall to clear the Back of the Valve covers on both side for the BBC
so to "Make do"
temporary modifie to bring down the saddle part were the mount bolt through till i can sort out the FI
I'm still not 100% sure I'm going to use this Motor/Trans set up
My plan for this truck
give it some much needed love
Make it Running driving truck on a low budget
..... I'm getting really close
......Sp
Old 11-17-2019, 12:34 AM   #16
Captainfab
60-66 Nut
In the '63-'66 trucks, the 230/250 I6 and 283,327 small block engine mounting brackets are exactly the same and bolt into the same location. If you picked up a set of original brackets, your engine would drop right into place, no messing around.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
