Old 09-20-2019, 11:57 AM   #51
HO455
HO455's Avatar
Re: 1971 4x4 Suburban Project - the 'Family Adventure Wagon'
Looks like a couple of future hot rodders in the making.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 09-28-2019, 11:10 PM   #52
allchevy58
allchevy58's Avatar
Nice looking Suburban, like what you've done to it. Maybe we'll see you around town.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 09-29-2019, 06:16 PM   #53
ManNamedJed
Thanks. Cool to see there are several Reno area members here!
ManNamedJed is offline   Reply With Quote
Old 09-29-2019, 06:21 PM   #54
ManNamedJed
Added some slip on seat covers today. My seats are actually very nice and the front has been reupholstered by the previous owner. But I've got kids and a dog, so I wanted to protect the seats.
I would have loved to find some that resembled the 'highlander' plaid, but didn't find anything. So I decided to go with traditional horse blanket. They certainly look period correct. Reviews for the $40 ones on Amazon weren't encouraging, so I got these from FIA out of Canada. I'm pretty happy with them. They are certainly heavy duty.
My back / middle seat is from a 74ish suburban so it is a 70/30 split. Good luck finding anything to fit that. However I realized I'll usually have the small seat folded up, so I got a small bench seat cover like for an old toyota and it did pretty good for the long section, just a bit long.
Old 09-29-2019, 06:28 PM   #55
ManNamedJed
Still struggling with my vibration. Put it up on stands today and found this. Driveshaft has some up and down motion. Not sure if it is the shaft or the axle. Axle was used, driveshaft got shortened when it was all installed.
Emailed the company that shortened the shaft and will see what they say.
Can't figure out how to embed the video, but here is a link:
https://youtu.be/hykrsMDBKdg
Old 09-29-2019, 07:26 PM   #56
ManNamedJed
Longer version, in case anyone is that bored....
https://youtu.be/IF4LGGbXGSE
Old 09-29-2019, 09:31 PM   #57
LockDoc
The Original Thread Killer
LockDoc's Avatar
Looks like the whole assembly is moving in and out of the third member. I wonder if it is the bearing that is bad. That would also let the shaft move up and down.... Dunno' I will look at it again
LockDoc
Leon
Old 10-06-2019, 01:32 PM   #58
ManNamedJed
Got my driveshaft rebalanced. I noticed when I brought it back in that it had one weight on one end. Now it has two weights on one end and a weight on the other end.
My vibration is still there, but significantly reduced. What remains could be a bit of tire vibes or due to pinion angle. Its good enough I feel okay driving it.
Also scored a serpentine belt kit at Summits scratch and dent pile. Was $987, got it for $380.
Old 10-06-2019, 08:21 PM   #59
LockDoc
LockDoc's Avatar
Glad you got part of it resolved anyway. That is a steal on the serp setup. Was there something missing?
LockDoc
Leon
Old 10-20-2019, 05:20 PM   #60
ManNamedJed
Still chasing a vibration!
Found one rear tire had a bit of a bounce, and decided the hub was a touch loose. Tightened and and no change.
Took it to the place where I had the driveshaft shortened and took him for a ride. The best he could come up with was that the transfer case output seemed a bit sloppy. So I'm going to do a fluid change and replace the output bearing and seal. Not very optimistic that is the issue.
Old 10-20-2019, 05:25 PM   #61
ManNamedJed
Decided to take a break from chasing the vibes and do some simpler projects.
My headlights have been a bit flaky, so I decide I might as well upgrade them.
I did some research here and liked the H4 and relay upgrades some guys do so I decided to take that route.
Bought Cibie 82440 H4 housings on ebay for $94. Also bought a H4 relay harness for about $20.
On Amazon I bought some H4 80/100W bulbs.
Got everything installed in about an hour. Haven't had a chance to drive at night yet to test and align/aim, but they certainly are brighter than stock, and now the headlight voltage doesn't need to go through the dash switch.
Old 10-20-2019, 05:30 PM   #62
ManNamedJed
I also did some tuning. I thought my advance came on early and had too much, so I changed some things. I have the MSD Streetfire HEI.
I changed springs to the next level firmer based on the spring kit instructions. I also added the vacuum advance limited to setting 'B'. This was all based on what I've read has worked well for others.
My carb is an Edelbrock 1406. I've read many people swap the jets/rods for those that come stock in the 1405. So I made that change too.
The result was a nice improvement in responsiveness and acceleration. I feel it has a fair bit more power from 2-3000 rpm. So if you have a MSD dist and/or a 1406 carb, I suggest trying out these changes.
Old 10-20-2019, 10:42 PM   #63
HO455
HO455's Avatar
You might try to find a shop that has one of these analyzers to locate your issue.
https://www.vehicleservicepros.com/i...iagnostic-unit
Old 10-21-2019, 11:42 AM   #64
Ol Blue K20
Just hanging out
Ol Blue K20's Avatar
Subbed to watch!
Dale
Old 10-21-2019, 01:42 PM   #65
ManNamedJed
You might try to find a shop that has one of these analyzers to locate you issue.
Sweet - another tool I need!
I don't imagine that's something NAPA will rent/loan.
I overheard two guys talking at the airport about Dodge using a system like this to diagnose vibrations. I wonder if the local dealership has one.
Old 10-21-2019, 03:07 PM   #66
HO455
HO455's Avatar
I'm not surprised to hear a Dodge dealer having one. I've had a little exposure to a couple of later model Dodge 4x4 3/4 tons and drive the drive train vibration issues when they get up around 100k on them. All that Cummins torque takes its toll.
Old 11-09-2019, 02:00 PM   #67
mrtoni
Kinda looks like yours. Got an extra
mrtoni is offline   Reply With Quote
Old 11-09-2019, 03:28 PM   #68
HO455
HO455's Avatar
North Cascades!!! I love that place! If you ever have a chance to go, do it!
Old 11-09-2019, 04:18 PM   #69
CG
BlahBlahBlah
I should have picked up a bunch of those when I was up there. Stupid Stupid Stupid lol.
Im not sure if you can even get them online anymore.
Old 11-09-2019, 04:23 PM   #70
mrtoni
The shipping was the killer. $12 bucks
Old 11-11-2019, 02:34 PM   #71
ManNamedJed
Sweet! Where do I get one of those?
Old 11-11-2019, 02:37 PM   #72
mrtoni
So they’re 16.99 plus 11 shipping ouch! Good news. I bought an extra. $25 and I’ll drive it over from sparks. Or google northern cascades institute
Old 11-11-2019, 03:15 PM   #73
ManNamedJed
Thank you, I appreciate that.
Here's the link for anyone interested:
http://north-cascades-institute.shop...r-14-x-22.html
Yeah $17 for a 14" poster is pretty steep. Too bad it isn't blue!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
