Old 05-27-2019, 11:59 PM   #1
SunSoaked
SunSoaked's Avatar
Swapped PCV & gained big time!
Ok, so I've finally got my 350 Vortec running great. The one thing I had been putting off was swapping the Wagner dual stage pcv. Today, I got r done.
With engine warmed up at idle I had 15 inches of vacuum and a very slight lope.
Then I swapped valves and t'd in the purge line from the charcoal cannister.
Started engine and adjusted valve per instructions.
The idle went up 300 rpm. I adjusted it back down.
It idles extremely smooth and I lost the lope I had. It now idles with 19 perfectly steady inches of vacuum and has noticeably better throttle response.
These aren't cheap, but worth every penny IMO.
SunSoaked is offline   Reply With Quote
Old 05-28-2019, 12:23 AM   #2
geezer#99
geezer#99's Avatar
Re: Swapped PCV & gained big time!
Good info!
And here’s a link to it if others are interested.
http://mewagner.com/?p=444
Old 05-28-2019, 12:43 PM   #3
weq92f
That's a cool idea...
These guys like it too:
https://www.hemmings.com/blog/article/let-it-out/
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-28-2019, 01:40 PM   #4
cashforclunkers
cashforclunkers's Avatar
Good stuff. Never knew. I will be keeping this in mind. Thanks
Joel
71' K10 stepside build
70'/04' GMC Crew cab project build
Bunch of parts for sale
Burb parts for sale
cashforclunkers is offline   Reply With Quote
Old 05-28-2019, 08:35 PM   #5
hjewell2
hjewell2's Avatar
Thank you for the post on this , wanted to try one but the price stopped me not knowing if this was snake oil. Now I will pay the money knowing it works according to your write up.
hjewell2 is offline   Reply With Quote
Old 05-29-2019, 04:30 PM   #6
Tom
driving is in my blood
Tom's Avatar
I've never even heard of custom PCV valves, heck never even thought about it before.
Old 05-29-2019, 07:22 PM   #7
AcampoDave
AcampoDave's Avatar
Be careful, last time a guy claimed he gained big time from one of those, the poor guy got shot down big time. http://67-72chevytrucks.com/vboard/s...d.php?t=630891 Edit: after reading all the info on the website, I ended up shelling out for one too.
AcampoDave is offline   Reply With Quote
Old 05-29-2019, 11:06 PM   #8
SunSoaked
SunSoaked's Avatar
Ya, I'm not gonna make any claims in improved gas mileage.
I'll leave the logic behind it's design and function to thier website. It convinced me to try it. As I said, it smoothed out my idle, gained 5 inches of vacuum and improved throttle response. My simple mind thinks of the pcv as a big vacuum leak sucking in contaminated air. Being able to restrict it at idle and open it up during cruise when the engine is creating more vapor makes sense to me.
Old 05-30-2019, 11:04 AM   #9
mattfranklin
mattfranklin's Avatar
Interesting. I'll have to read up on what they're doing.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 05-30-2019, 12:02 PM   #10
tdangle
tdangle's Avatar
Wonder, would eliminating the PCV valve also increase idle vacuum?
Terry
1970 Custom Camper/C20 , GM Crate 350/2004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-30-2019, 02:03 PM   #11
weq92f
Well... it depends...
The PCV valve is supposed to restrict air flow under high vacuum ( idle ) conditions down to something small enough not to affect idle quality. That is, the controlled vacuum leak that is the PCV system is supposed to go away at idle.
If the PCV valve you have currently isn't doing that, then you have too large a vacuum "leak" at idle as a result, which will cause the things that vacuum leaks cause!
Easy enough to check. Before I recently replaced my non-functioning-properly PCV valve, plugging the vacuum line to it caused idle to clean up very nicely ( just as if a vacuum leak had been plugged ) and likely did increase overall Hg as well!
-klb
Old 05-30-2019, 03:34 PM   #12
tdangle
tdangle's Avatar
-klb
It just hit me how the dumb thing works! Always wondered how and was always told shake it. If it rattles it's OK. Now I understand at high vac such as cruise or idle the weight (or what ever it is) pulls up and pretty much closes off the sucking from the engine/valve cover. At lower vac levels the weight drops and the engine can pull vapors from the engine. What a simple design!
Terry
Old 05-31-2019, 11:29 AM   #13
SunSoaked
SunSoaked's Avatar
You got it. Keep in mind that the factory engine produces a specific amount of vacuum therefore the factory makes a pcv specific to that engine. When you alter the engine with a cam, timing, carb, etc the pcv is no longer matched to the engine characteristics. This is the beauty of the Wagner valve. You can adjust to function in harmony with any engine. It should be the last pcv you ever buy.
Old 06-15-2019, 12:01 PM   #14
AcampoDave
AcampoDave's Avatar
Ok so here's what i gained on my '64 longbed with a mainly stock '61 283 with the street breather previously converted to a PCV. The vacum went from 19hg to 20hg and the idle increased by 200 rpm. After restoring the original idle rpm, the motor ran smoothly and seemed to have a cleaner idle. It wasnt easy tuning the valve due to it's location on my engine but it was doable. I had to use extra caution to prevent the valve or the allen wrench from slipping thru my fingers and falling behind the engine. (Allen wrench still did, thankfully it didn't drop down the pcv hole.) Would I do it again? Sure. In fact I'm gonna, as soon as i get my '66 back on the road. It's 283 has been moddified a bit with the usual stuff so we'll see how much difference it makes on that one in a month or two.
Old 06-16-2019, 08:08 PM   #15
SunSoaked
SunSoaked's Avatar
Two thumbs up!! I don't regret spending the $ one bit.
Old 06-17-2019, 02:11 PM   #16
toolboxchev
Wondering if anyone is using this product with an older style gen 1 block and how they configured it?
Appreciate the responses!
toolboxchev is offline   Reply With Quote
Old 06-17-2019, 02:35 PM   #17
SunSoaked
SunSoaked's Avatar
Breather on one side, pcv in the other. Boom done.
Old 06-17-2019, 06:11 PM   #18
RodnRudy
RodnRudy's Avatar
After reading this post I ordered one of the adjustable Wagner pcv valves and installed it on my Gen 1 350. Watched the video half a dozen times and followed the directions. It smoothed out the idle just like it's supposed to. I also had a problem with oily residue accumulating around the carb at the vacuum port. I'll monitor that and adjust the valve if needed.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 06-17-2019, 11:07 PM   #19
SunSoaked
SunSoaked's Avatar
Nice. That's a good looking engine. I love those valve covers.
Old 06-19-2019, 04:51 PM   #20
MySons68C20
MySons68C20's Avatar
I just ordered one of these and will share my before and after.
Thank you.
Blake
MySons68C20 is offline   Reply With Quote
Old 06-23-2019, 08:12 PM   #21
bosephus
bosephus's Avatar
Per their website,they offer a 25% discount for a group buy of 8 or more units.
bosephus is offline   Reply With Quote
Old 10-03-2019, 06:37 PM   #22
kelz702
I've been thinking about ordering one of their PCV valves for awhile now. I'm glad I found this post. I've been having a hard time getting my truck to idle correctly. I bought a dress up pcv valve from Summit awhile back when I had the motor built and im pretty sure its what's been giving me issues. The QuickFuel carburetor doesn't seem to have the adjustability that it should have. Is anyone else interested in buying one at the group rate with the 25% off discount? It looks like we only need 8 people
kelz702 is offline   Reply With Quote
Old 10-03-2019, 06:52 PM   #23
geezer#99
geezer#99's Avatar
I see a 4 corner idle on your carb.
Which quickfuel is it?
Old 10-03-2019, 06:59 PM   #24
kelz702
It's a Quickfuel HR-650 Hot Rod Series with Mechanical secondary
Old 10-03-2019, 07:17 PM   #25
geezer#99
geezer#99's Avatar
People have been having idle problems with a bunch of quickfuel carbs.
Maybe you’ll find some info here on a 670.
https://www.hotrodders.com/forum/hol...ix-507033.html
What do you run for timing?
Initial?
Mechanical?
Vac advance numbers?
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
