Old 10-14-2019, 10:49 PM   #1
66_c10_tpi
Upgrade to Front Coilover
I am looking to upgrade the stock front suspension to coilovers. Looking for recommendations on whose systems to use?
66_c10_tpi is offline   Reply With Quote
Old 10-14-2019, 11:25 PM   #2
Captainfab
60-66 Nut
Re: Upgrade to Front Coilover
Porterbuilt makes a very nice coil over front suspension.
http://pbfab.com/67-72-front-dropmember-coilovers
Old 10-15-2019, 05:29 AM   #3
66_c10_tpi
Thanks Captainfab but that is a little out of my price range. I am thinking more along the line of something that uses the factory cross member.
Old 10-15-2019, 06:47 AM   #4
PGSigns
PGSigns's Avatar
QA1 has a setup to di it with the stock front cross member.
https://www.qa1.net/complete-c10-fro...version-system
Still not a inexpensive swap.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-15-2019, 03:22 PM   #5
66_c10_tpi
PGSigns I will check them out. Thanks
Old 10-15-2019, 04:31 PM   #6
forestb
forestb's Avatar
cpp sells one also
forestb is offline   Reply With Quote
Old 10-15-2019, 06:15 PM   #7
66_c10_tpi
I have checked the QA1. One issue I see is that you have to adjust the ball joints every 3000 miles or annually which ever comes first. To do this you have to disconnect the ball joints from the spindle. This might be Ok if it was a race vehicle but I don’t think i would want to have to do this.
Old 10-15-2019, 11:30 PM   #8
Captainfab
60-66 Nut
If you can fabricate or know someone that can, this will give you some idea what can be done with the stock front suspension
http://67-72chevytrucks.com/vboard/s...light=coilover
Old 10-18-2019, 07:44 PM   #9
66_c10_tpi
Captainfab I have looked at the link. Since I don't have tubular arms I will probably just purchase the system from POL. I am still not for sure if I want to go the coil over route or just upgrade to tubular arms.
Old 10-18-2019, 11:19 PM   #10
Captainfab
60-66 Nut
You don't have to have tubular control arms to convert to coilovers. You will just have to fabricate something different for the lower mount than what was shown in the link.
Old 10-21-2019, 06:21 PM   #11
SCOTI
SCOTI's Avatar
Nobody else has asked so I will.... What is your intended driving 'style'?
If all you plan on changing is the stock coil spring for a 'coil-over' & want to keep everything else the same (parts), how is swapping to C/O's an upgrade?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 10-21-2019, 06:49 PM   #12
66_c10_tpi
I am not going to autocrossing or anything. I just want something will be comfortable on long drives. I was first thinking of just upgrading to later model a arms. But by the time i purchase a set out the junk yard and rebuilt them i would still have a system 40 years old. I was then thinking about tubular a arms. But if i go that route then decide later on coil over i would have to modify them. My truck is torn down now and i thought this would be the perfect time to do the install.
I was hoping to get some responses from someone that has done the change over and see how they like it.
Old 10-21-2019, 07:24 PM   #13
SCOTI
SCOTI's Avatar
If you plan to re-use 6x-87 control arms, I'd just stick w/the factory coil set-up & invest in adjustable shocks.
Hotchkis has a nice 'updated spec' OE arrangement set-up.
Ridetech has a C/O front suspension kit the bolts to your original style crossmember after some old parts are removed (requires busting some rivets).
QA1's stuff looked pretty nice when I saw it @ the C10 Nats earlier this year. Not sure why the BJ requires adjusting. That alone would steer me elsewhere.
NoLimit has a nice set-up but it's a complete crossmember swap as is Porterbuilts C/O stuff.
If you're just driving, I would opt for arms that pivot vs bind. Delrin is hard & pivots; Poly is hard & binds; Rubber binds but offers cushion/flex so the bind isn't as pronounced. Aftermarket arms offer the possibility for increased caster but that can also be obtained using tweaked OE parts by re-drilling the lower a-arm cross-shafts to push them forward. A decent spring rate (800-1,000# fronts), some adjustable shocks, fresh steering box w/modern ratio & a good sway bar is night/day diff vs a stock spec set-up.
So, upgrading to a better suspension can be done using the OE parts but it's still based on >50yr old technology (albeit improved). An aftermarket set-up can be had w/updated technology & R&P steering. Your budget will likely steer some of the decision process.
What's the budget?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-21-2019, 08:23 PM   #14
66_c10_tpi
I am hoping to not spend over $1500.
Old 10-22-2019, 12:18 AM   #15
SCOTI
SCOTI's Avatar
Then rebuild the front suspension & dial in the alignment to modern set-points vs. 60's/70's specs. Adjustable shocks (just shocks; Ridetechs) would be over/around $400.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-22-2019, 12:37 AM   #16
SkinnyG
SkinnyG's Avatar
+1 on rebuild what you have and give it a modern alignment.
If you just want the ability to adjust ride height, look into circle track weight jackers.
Nostrildamus - 1961 Apache, now under the knife
The Crusty Chevy - 1977 Silverado, shortboxed & dropped, potato-potato.
The Fiendish Firefly - The ultimate engine swap: 5.7lbs in a 1lb bag
The Lethal Locost - Street legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-22-2019, 05:48 PM   #17
theastronaut
theastronaut's Avatar
Coilovers aren't anything special other than being able to easily adjust the ride height if you're not racing. If you're racing then having known spring rates that are easily exchanged can be a benefit of since springs are available in a wide range of rates and lengths. But you can get the same performance or ride quality with separate springs and shocks.
If you're just looking for ride comfort then you can get good results from the stock suspension with a few mods. These trucks ride and drive pretty good with good shocks and a good alignment. I would suggest an alignment that has -.5 camber, as much caster as possible, and around 1/16" toe in. You can modify the lower control arm shafts to allow more caster if needed. Lowering the truck with drop spindles will lower the center of gravity so it'll have less body roll/pitch through curves and over bumps.
The biggest single upgrade you can make for drivability will be to swap the stock steering box for a CPP 500 series quick ratio power steering box, or a No Limit Engineering rack and pinion kit. The stock steering box's really slow ratio is pretty annoying, and most are worn with a lot of play in the steering wheel now.
My old '66 had dropped spindles/disc brakes from CPP, stock springs with 1.5 coils cut off, the bump stop bracket completely cut off, upper shock mount relocated farther up the frame, KYB Gas-A-Just shocks, and CPP's 1.25" sway bar. The rear had the shocks relocated to the outside of the frame rail, drop springs, drop blocks, a small pipe notch, and an 80's F150 sway bar. The truck rode better than dad's completely stock '66 due to the better shock damping rates, lower center of gravity, and sway bars. It drove great on the interstate- tracked straight and was very stable even over 90 mph. I sold it before I swapped over to CPP power steering, that would have been the only thing I would've changed. You could easily stay within your budget doing these mods and have a really great driving truck.
IMO, there's no reason to "upgrade" to 73-87 a-arms. The geometry isn't improved any, and the rubber bushings wear out/go soft/rot over time. The inner rubber bushings are also much larger diameter so it reduced ground clearance on lowered trucks, and that's already the lowest point of the truck.
theastronaut is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
