Old 10-21-2019, 08:27 AM   #1
jbgroby
jbgroby's Avatar
29 spot welds in less than 2 1/2 feet......
Bless GMC for the many spotwelds, esp on the compound curves of a upper trans hump cover. Tried my best with a spotweld cutter, but the metal was tougher than the blade. I had to drill each one first with a 1/8 titanium drill bit (standard steel wore out quick). Then I followed up with a stepdrill to 1/2", panel came off smoothly. The main floor hump is bolted on, O wonder whay GM decided to spot weld that vs. put in bolts? I putting it back with 5 cage nuts and some sealant.
The upper trans shield had to be removed in order to access the 4" x 4" inspection plate so I can get to the 32 torus cover bolts (think torque converter) that hold it directly to the flywheel. It also allows me to get to the 5 bolts that hols on the bellhousing.
Oh the JOY! I remember when I assembled the trans., I had a friend's kid start each one for me. One bit of good news is that the Torus cover dran plug just happened to be sitting right on top.
Does skin still grow back on the knuckles.......asking for myself!
jbgroby is offline   Reply With Quote
Old 10-21-2019, 11:05 AM   #2
mattfranklin
mattfranklin's Avatar
Re: 29 spot welds in less than 2 1/2 feet......
Wow, that's a lot of work. The access looks great, though.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 10-21-2019, 11:32 AM   #3
Bigdav160
Bigdav160's Avatar
Rare to see a hydramatic in a truck
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-21-2019, 11:35 AM   #4
jbgroby
jbgroby's Avatar
It was the high-end optional, I would have considered repairs, but really want the overdrive. The trans, bellhousing and flywheel are FREE TO GOOD HOME, Just come get it.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
