Old 12-09-2018, 11:12 PM   #126
Barnfind46
Barnfind46's Avatar
Re: What did you do to your truck today.The 3rd chapter
Went to summit to pickup a new GM 350 crate engine. My old engine has numerous issues and now it is using oil.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 12-10-2018, 08:38 PM   #127
noxqsz
Out with the old seat, in with the new (to me) seat, plus a new dash pad, refurbished cluster bezel, and door handle and window crank escutcheons. I'm going to install the new glove box liner as soon as I get my radio fixed and installed.
noxqsz is offline   Reply With Quote
Old 12-12-2018, 05:55 PM   #128
Barnfind46
Barnfind46's Avatar
Readied my new engine for installation.
Old 12-13-2018, 05:04 PM   #129
OldBlue70C10
https://photos.app.goo.gl/f7YgUPK1Kv9zrdr77
This wasn't today, it was Monday, but I finally got my grandad's truck moved to my house. But not after it was broken into, and a bunch of new parts stolen. But she's safe in my driveway now. I still haven't gotten this adding photos down, it wasn't showing up, so i just added a link to the photo
OldBlue70C10 is offline   Reply With Quote
Old 12-13-2018, 05:18 PM   #130
nlped
nlped's Avatar
Here yah go OldBlue70C10
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-13-2018, 05:20 PM   #131
OldBlue70C10
Thanks! I appreciate that
Old 12-16-2018, 08:16 PM   #132
Barnfind46
Barnfind46's Avatar
Got a little closer to starting it!
Old 12-16-2018, 09:19 PM   #133
kcmarkd
kcmarkd's Avatar
Finished redoing the AC box under the hood. The goal was functionality, and to stop being a hostel for furry rodents. Originally, the inboard side of the box had two holes where the original vacuum canister had been mounted. Sometime in the past 50 years, it was forcibly removed, leaving two perfect mouse sized holes. So, took it upon myself to try and repair it by doing fiberglass for the first time ever. Of course, after removing the whole system and getting rid of the old mouse funk...
Before, during, and after:
Size:  29.5 KBName:  AC-Box-BigHole.jpg
Size:  27.7 KBName:  AC-Box-Redone.jpg
This is an AC truck, but the system had been open to the elements for who knows how long, so instead of reinstalling the non-working evaporator, rusty POA and other stuff, I simply plugged the two grommets to try and seal up the case. Also, fiberglassed a metal bar to the inside of the side panel with tapped threads I can remount the replacement vacuum canister.
1970 C10 CST, PS, PB, AC, patina, original, work in progress
kcmarkd is offline   Reply With Quote
Old 12-16-2018, 09:29 PM   #134
kcmarkd
kcmarkd's Avatar
After the AC box was back in, I decided to take a look at the drip rail to see how difficult it would be to remove. Tried to pry a little of the old, dried, separated seam sealer, and before I knew it, I had most of it out. And, I had told my wife that I was going to wait on that job.
Most of it came out fairly easily, then I attacked it with a wire wheel. Some surface rust, but no holes and no rust through!!
So, decided to use some rust reformer just to make sure there wasn't something hidden, so masked it all up and shot a coat on it.
Size:  27.0 KBName:  Drip-Edge-Encapsulated.jpg
The goal is to let this cure overnight, then tomorrow evening I am planning to attempt to redo the seam sealer. I have the 3M 8307 for the horizontal section, then 8308 for the vertical sections. Never done seam sealer before, so it should be interesting...
Old 12-16-2018, 09:53 PM   #135
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
I finally got the spot light in. That drilling is a nerve wracker! But it's done and tested. Final wiring will be done sometime this week we ran out of day light.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-16-2018, 10:15 PM   #136
Ken O.
All new ball joints and steering arm linkage and an alignment. Drives way better now.
Ken O. is offline   Reply With Quote
Old 12-16-2018, 11:39 PM   #137
KQQL IT
At the body shop.
KQQL IT's Avatar
Dimmer switch died on the way home.
Transmission mount needed some attention and some quality time spent.
Old 12-18-2018, 04:21 PM   #138
3757chevy
3757chevy's Avatar
Received my replacement heater control levers from LMC Today . I got mine replaced in my '67, I ordered one for my Daughters defrost lever for her '72 and and extra air/fan lever , just because.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 12-18-2018, 06:02 PM   #139
Chris_oz
Chris_oz's Avatar
Fitted new door handles, new hood emblem.
Also got to put registration plates on her.
That felt good, 3 months of it sitting in the driveway, now I can drive it.
Chris_oz is offline   Reply With Quote
Old 12-18-2018, 11:37 PM   #140
Steeveedee
Who Changed This?
Steeveedee's Avatar
Discovered that the kluge fitting setup on one of the aftermarket trans cooler lines is leaking. It goes from 5/16" tube to 1/8" pipe to some other fitting to some other fitting to 3/8" hose. I am looking for a fitting that adapts from 5/16 compression to 3/8 hose in one step. I'm convinced that it exists, I just have to go look for it. Tomorrow morning is soon enough.
~Steven
Simi Valley, CA
Old 12-22-2018, 04:25 PM   #141
RodnRudy
RodnRudy's Avatar
I installed a new heater box resistor and blower switch. I've got all three speeds now, was missing the high setting, and installed a new glove box. Didn't have as much luck with the glove box light assembly. The thing fell apart when I tried to put it in. Some of these parts are pretty clunky junky!
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 12-23-2018, 01:04 PM   #142
el_fantasma
el_fantasma's Avatar
Original glove box came with a light?
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 12-23-2018, 01:18 PM   #143
weq92f
I would think if so, it would have been later, like 71/72. LMC lists the part through the entire range though...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-23-2018, 01:19 PM   #144
fdbdw
fdbdw's Avatar
New wheel, smaller than my old one, shorter adapter = a little more leg room
fdbdw is offline   Reply With Quote
Old 12-23-2018, 02:04 PM   #145
RodnRudy
RodnRudy's Avatar
In my sideways glove box pic you can see in the upper left hand corner a hole for the switch, the lite would be on the other end. My 68 didn't have a lite and I've not seen one in any truck but I thought it would be neat. Also my wiring harness has the hot wire for the lite. American Autowire harness by the way.
Phil
Old 12-23-2018, 02:57 PM   #146
ApacheNick
Killed my transfer case. Still drives fine in 2 wheel drive but locks up after about 50 feet in 4.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 12-23-2018, 06:27 PM   #147
RodnRudy
RodnRudy's Avatar
Well since I love a challenge and I was bored today and pissed about that glove box switch that broke, I decided to see if I could fix it. So I fired up the mig and was able to tack weld the the metal piece back together without melting it. Put it back together, installed it in the glove box, wired it up and Viola I've got a working glove box light! Truck's probably worth a lot more now,LOL
Phil
Old 12-23-2018, 06:37 PM   #148
FL71C10
Finished clamping my fuel lines to the frame.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-26-2018, 01:18 PM   #149
elorenzof
Well this past week i cleaned the cab out including the fuel tank, installed dynamat type product, cut the jute backing for under the carpet and test fit the carpet. still trying to decide if i should put the seats in from a 2013 Silverado i purchasd from LKQ or just the bench seat. problem is i dont have the know how to weld and i need a frame made for the silverado seat as i don't want to drill holes into the cab. The bench seat is perfect i just wanted the silverado seats in it.
elorenzof is offline   Reply With Quote
Old 12-26-2018, 02:08 PM   #150
elorenzof
Attachment 1848048
Attachment 1848049
Attachment 1848052Attachment 1848051
i'm interested in how the seam sealer project turned out?
