10-31-2018, 07:51 PM | #1 |
hydroboost unit fitment ?
i see there is specific part #'s for these .
i have a real clean uni from a c-10 diesel truck with good hoses . want to swap it in place of my NASTY / RUSTY / READY TO POP lines unit i was going to use from old truck to new . i dont recall much of any info on how there different from each other . there both from 80's gm trucks . anyone know the difference or if you have a 1/2 ton unit on a k30 with k30 master and no problems. i have a new master to install on the unit when i install a good non rusty/crusty unit .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-01-2018, 10:11 AM | #2 |
Re: hydroboost unit fitment ?
I'm about to put hydro-boost on my 85. I have 3 systems-all mid 80's. I had pulled some units off of military 1009/1028s. Those were the Blazer and k30s. The units themselves are exactly the same. When I put the axles in my K20 they had much bigger brakes (Dana 60/13x4 drums). The only difference I found was with the master cylinder and it's bore size. All the hoses and fittings were the same between the Blazer, C30, and K30.
11-01-2018, 11:15 AM | #3 |
you look them up for each part for specific truck and there separate part #'s for the hydroboost unit .
oh well i guess i will try and see what i get .
11-01-2018, 12:07 PM | #4 |
I got two friends that have them on thier cars with big nasty engines that don't produce any vacuum. One of them we pulled off an astrovan. I don't think there's any difference in the unit themselves. Just match the master cylinder and go for it.
