06-23-2018, 08:22 PM | #676 | |
Re: 64 C10 Stepside "Jaybird"
Door7 by bjohnson388, on Flickr Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
06-23-2018, 08:26 PM | #677 |
I got the inside of the Passenger door shot with color today. I haven't shot any color in almost 2 years. I have been working on this door off and on since October of 2016. Nice to finally almost be done.
20180623_121541 by bjohnson388, on Flickr 20180623_124136 by bjohnson388, on Flickr Sealer Epoxy Primer 20180623_144842 by bjohnson388, on Flickr 20180623_144852 by bjohnson388, on Flickr And color... 20180623_150605 by bjohnson388, on Flickr 20180623_150631 by bjohnson388, on Flickr 20180623_150646 by bjohnson388, on Flickr 20180623_150659 by bjohnson388, on Flickr
06-24-2018, 06:25 AM | #678 |
06-24-2018, 04:15 PM | #679 |
Excellent Bret.
Thank you for the previews.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
06-24-2018, 04:23 PM | #680 |
Looking good Bret nearly there well done
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
06-28-2018, 07:01 PM | #681 |
Thank You Mike
Thanks Rian Good to hear from you Martin. Looking forward to your updates. Bret
06-28-2018, 07:02 PM | #682 |
Today's work. Started early this morning getting chores done around the house and then got the door prepped to spray the Blue. I missed a few very small dents and it orange peeled on mine just a little. But it's an old truck and not a show truck for sure. I thinned the paint a little extra but it still wasn't enough. I will reduce in more on the next round.
20180628_132633 by bjohnson388, on Flickr 20180628_132628 by bjohnson388, on Flickr Tape and masking pulled. Pretty happy with it. Chubbed as Rian would say. 20180628_151322 by bjohnson388, on Flickr 20180628_151335 by bjohnson388, on Flickr 20180628_152315 by bjohnson388, on Flickr 20180628_152337 by bjohnson388, on Flickr Can't wait to get it mounted on the truck for the last time. Speaking of that. The hinge bolts were not ready so sandblasted and put them in paint this evening. 20180628_160357 by bjohnson388, on Flickr The passenger front fender will be next in the paint booth. Fixed 3 small places with glazing putty and put another coat of high build on. Will block it out tomorrow after work and see if it is ready for paint. Hopefully get some color on it this weekend and get the inside of it painted as well and reinstall all the inside brackets and rubber pieces. 20180628_164124 by bjohnson388, on Flickr Carefully got the door into it's temporary home for next few days. 20180628_160116 by bjohnson388, on Flickr These photos popped up from 4 years ago. FB_IMG_1530213920787 by bjohnson388, on Flickr FB_IMG_1530213891207 by bjohnson388, on Flickr FB_IMG_1530213870012 by bjohnson388, on Flickr Thanks for stopping in, Bret
06-28-2018, 07:11 PM | #683 |
07-01-2018, 10:51 AM | #684 |
Nice job Bret! Once you get it done I'll meet you at the monthly Leander car show!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
07-02-2018, 07:03 AM | #685 |
Paint looks pretty darn Good. Thanks for the pictures
07-11-2018, 08:13 AM | #686 | |
Bret
07-11-2018, 08:14 AM | #687 |
Some more updates.
Before. DSCN8379 by bjohnson388, on Flickr After. Exactly 4 years apart. 20180705_094540 by bjohnson388, on Flickr 20180705_094502 by bjohnson388, on Flickr 20180705_100736 by bjohnson388, on Flickr I think my lines are pretty close considering I painted these pieces separately and more than 3 years apart. 20180705_100748 by bjohnson388, on Flickr 20180705_100758 by bjohnson388, on Flickr 20180705_094457 by bjohnson388, on Flickr thanks for stopping in, Bret
07-11-2018, 08:17 AM | #688 |
So last Thursday I got the Driver vent window rebuilt. What a Pain in the ass that was. My fingertips are all still hurting.
First job was getting these factory style rivets into this metal impregnated seal. 20180705_104427 by bjohnson388, on Flickr I had to use a drill bit to help guide it in. 20180705_104435 by bjohnson388, on Flickr 20180705_104441 by bjohnson388, on Flickr Next was fitting the outside seal into its frame. I didn't take any pictures other than this but this is the reason for my fingers hurting. Took a good 30 minutes and some soapy water to get it fully seated. 20180705_113658 by bjohnson388, on Flickr Next was fitting the glass back into its frame using original style rubber cork glass setting tape. 20180705_113839 by bjohnson388, on Flickr Use electrical tape so when you trim it you can't see the tape. 20180705_114450 by bjohnson388, on Flickr Was actually easier than I thought it was going to be. 20180705_114854 by bjohnson388, on Flickr Used an Exacto knife to trim off the excess. 20180705_115633 by bjohnson388, on Flickr 20180705_115643 by bjohnson388, on Flickr Still need to set the rivet that goes in the window hinge. I want to test fit in the door first to make sure everything lines up. 20180705_121154 by bjohnson388, on Flickr New vs Old. 20180706_195647 by bjohnson388, on Flickr Front fender parts out of the paint shop and ready to have the rubber assembled on them. I will be using some heavy gauge coated wire instead of staples. 20180706_195734 by bjohnson388, on Flickr Another before/after 4 years apart. DSCN8397 by bjohnson388, on Flickr 20180706_185214 by bjohnson388, on Flickr Bret
07-11-2018, 08:19 AM | #689 |
Got all 4 fender brackets done with new rubber and staples installed.
Rubber that goes on top bracket that seals against the cab. 20180707_185250 by bjohnson388, on Flickr Coated wire I used to make staples. Got it at the Hobby Store in the jewelry making section. 20180707_185253 by bjohnson388, on Flickr Handmade staples 20180707_190117 by bjohnson388, on Flickr First bracket done. I don't like how it bunches in the corner. But that's how the factory did it. 20180707_191000 by bjohnson388, on Flickr 20180707_191005 by bjohnson388, on Flickr Bottom side 20180707_191011 by bjohnson388, on Flickr Both sides done. 20180707_192339 by bjohnson388, on Flickr Lower splash guards. 20180707_193934 by bjohnson388, on Flickr 20180707_193941 by bjohnson388, on Flickr Used this small drill bit in my dremel to drill holes through the rubber. 20180707_193944 by bjohnson388, on Flickr 20180707_193947 by bjohnson388, on Flickr 20180707_194018 by bjohnson388, on Flickr 20180707_194005 by bjohnson388, on Flickr 20180707_194021 by bjohnson388, on Flickr I made these staples the right width by bending one side putting it in the hole and the using the needle nose pliers bending right in line with the other hole. 20180707_194128 by bjohnson388, on Flickr 20180707_194321 by bjohnson388, on Flickr All 4 done. Can check that off my list. 20180707_195122 by bjohnson388, on Flickr Bret
07-11-2018, 09:09 AM | #690 |
Love the step by step! The stuff I have seen done on this forum boggles my mind! Everyone that takes the time to show us how they did things makes life easier for us that need help. Thanks Again
07-16-2018, 05:09 AM | #691 |
07-16-2018, 03:19 PM | #692 | |
It’s a record of progress
07-17-2018, 12:42 AM | #693 |
Wow very nice work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-18-2018, 08:42 AM | #694 | ||
A man of few words. Quote:
Thank You TJ. Bret
07-18-2018, 08:44 AM | #695 |
Update.
Tearing down the Passenger vent window so I can rebulid it. I only took one apart at a time that way I can reference the other one if I had trouble putting it back together. 20180708_103555 by bjohnson388, on Flickr I think this piece of rubber was past its lifetime compared to the new underneath it. 20180708_103633 by bjohnson388, on Flickr Detailed pictures of how all these spacers and washers go back. 20180708_102251 by bjohnson388, on Flickr 20180708_102237 by bjohnson388, on Flickr Everything but the rubber. 20180708_103911 by bjohnson388, on Flickr Next up taking the door glass out of the channels to rebuild them. I put tape on the ends to line the glass backup and I measured from the top and wrote each side down so I can get the glass back exactly where it goes. 20180708_122618 by bjohnson388, on Flickr 20180708_122622 by bjohnson388, on Flickr 20180708_122625 by bjohnson388, on Flickr Knocked the window channel off with a block of wood and rubber mallet. Was pretty easy. Glad I did this. There was a lot of corrosion in the channels and the glass setting tape was completely rotted out. 20180708_122808 by bjohnson388, on Flickr Everything blasted. 20180708_153924 by bjohnson388, on Flickr I blasted a ton of bolts today too and painted several as well. Still amazed at how many bolts are left to go on the truck. 20180708_153907 by bjohnson388, on Flickr Some more parts in Black paint. 20180708_141111 by bjohnson388, on Flickr Upcoming project and its ingredients. 20180708_104354 by bjohnson388, on Flickr 2 of the dogs sunbathing. 20180708_141027 by bjohnson388, on Flickr Several things knocked off my list. Bret
07-27-2018, 08:30 AM | #696 |
Couple quick shots I got of the fender installed. Still have to pull it back off and reshoot. Just wanted to get a glance.
20180723_075854 by bjohnson388, on Flickr 20180723_075847 by bjohnson388, on Flickr 20180723_080110 by bjohnson388, on Flickr 20180723_075837 by bjohnson388, on Flickr Sunrise from in front of my store for Rian. 20180724_073349 by bjohnson388, on Flickr The paint laid down really smooth. 20180722_194744 by bjohnson388, on Flickr Bret
07-27-2018, 09:06 AM | #697 |
Good job brett. Truck is looking great and you tell the story so well. I especially like the before and after photos.
07-27-2018, 09:18 AM | #698 |
07-27-2018, 08:10 PM | #699 | |
You are man of few words Mike. Bret
07-27-2018, 08:13 PM | #700 |
Next up was finishing the Passenger vent window. Made a run to Lowes to get a 5/16 fine thread nut and some nylon washers.
20180727_122302 by bjohnson388, on Flickr Installed the final rivet on the vent window. 20180727_081010 by bjohnson388, on Flickr 20180727_081013 by bjohnson388, on Flickr Last piece of rubber/felt to go on vent window. 20180727_130125 by bjohnson388, on Flickr The driver window is missing this lock tab washer so I made a copy of the passenger one before buttoning all up. Its not pretty but it works. 20180727_125727 by bjohnson388, on Flickr Installing the glass. 20180727_132052 by bjohnson388, on Flickr Rubber felt has the slits for the corner so it doesn't bunch up. 20180727_132059 by bjohnson388, on Flickr 20180727_132106 by bjohnson388, on Flickr Jeep Cherokee door check. Fits perfectly. 20180727_132116 by bjohnson388, on Flickr Passenger door is almost completely assembled. 20180727_141951 by bjohnson388, on Flickr 20180727_142000 by bjohnson388, on Flickr I attempted to install the felt that goes at the bottom of the window but had no luck and broke a tab on one of them. After research I see Precision makes a set with different clips versus the ones that come in their kit. That doesn't make any sense. Disappointed as everything else for the doors worked great. This is Precision brand. I have read to save the original clips but the ones on mine had already been replace and looked just like these. I have read several threads about it. I will either order the different set from Precision or maybe just screw them on like Astronaut did. 20180727_140854 by bjohnson388, on Flickr The fruits of all my labor. This door shuts factory fresh and sounds amazing. I haven't even put any sound deadening in it yet. I am really stoked and can't wait to get the driver door done. The sound of this door takes me back to being a kid and shutting the door on my Grandpa's 64' Longbed. Click pic for video. 20180727_141112 by bjohnson388, on Flickr Some Random shots. 20180727_142021 by bjohnson388, on Flickr 20180727_141945 by bjohnson388, on Flickr Bret
