12-01-2017, 09:31 PM | #1 |
96 k1500 runs bad
Hey all. Was driving my 96 k1500 350, it started missing and running horrible. Replaced cap and rotor, ran fine for a week then started doing the same. Plugs, wires, and timing chain and gears( was def. needed) fuel pressure at 54psi and holds KOEO. Compression is fine. Only code is P0300 random misfire. plugs #1 and #8 turning black. Thanks for any help.
12-02-2017, 06:18 AM | #2 |
Re: 96 k1500 runs bad
Sounds like spider going bad....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-02-2017, 07:36 AM | #3 |
second the spider
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
12-02-2017, 08:44 AM | #4 |
Thanks guys. Any way of knowing for sure once I get the plenum off? Can I hook the fuel lines back up and roll the key on and see gas come past the poppets or maybe a cracked tube?
