Old 02-04-2018, 04:42 PM   #1
808_67C10
808_67C10's Avatar
Ordered new wheels now trying to get an idea of tire size
I have a 85 c10 - up front (springs/drop spindle) and a flip kit in the rear (no c notch)
I ordered US Mags 20x8 for the front and 20x9.5 for the rear.
I looked through tons of threads and am having a hard time coming up with the right tire. I want a little more beef in the rear but not too much to make it look akward.
Anyone have any thoughts? I dont want to take out or modify my front fenders either - just want to do it right the first time.
Currently I have 275/50-15 rear and 225/60-15 front (the fronts are a bit too small)
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 02-04-2018, 08:17 PM   #2
LuvNLife
LuvNLife's Avatar
Re: Ordered new wheels now trying to get an idea of tire size
I used this chart to help me when I was shopping for tires:
https://tiresize.com/chart/
Stock diameter tires on our squares (2 wheel drive) were right around 29", so that's what I looked for on the rear. Up front, I went with something like 27.6 tall, since I wanted a bit of the "big and little" look...
LuvNLife is offline   Reply With Quote
Old 02-04-2018, 08:57 PM   #3
jrpontiac
jrpontiac's Avatar
jrpontiac is offline   Reply With Quote
Old 02-05-2018, 01:09 AM   #4
808_67C10
808_67C10's Avatar
yep, I have used the tire size chart to compare sizes but, looking for advice on too big, too small, too much side wall bulge... mainly what works for people so, I know it will work for me.
Old 02-05-2018, 03:25 AM   #5
layinrocker65
layinrocker65's Avatar
I have US Mag Ramblers in that size. 245/45-20 and 275/40-20. 2.5 spindle and one coil cut up front and a flip in the rear with no notch. I love the tire height combo.
You’d probably want to go slightly bigger in the rear if you want it a bit beefier.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 02-05-2018, 10:17 AM   #6
77c10
77c10's Avatar
I run 285/50/20 on the rear of mine on a 20" x 10" wheel
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 02-05-2018, 11:50 AM   #7
808_67C10
808_67C10's Avatar
Right on, thanks. I was thinking a 245/45 up front and maybe a 295/40 in the rear... u think the 295 may be too wide for the 20x9.5 outback?
Old 02-05-2018, 12:03 PM   #8
77c10
77c10's Avatar
I'm running 245/40/20 on a 8" wheel up front on mine. 295 is just a smidge wider, you may be able to get away with it.
295/40 is 11.6" versus a 285/40 at 11.2". I have barely enough room to fit two fingers between the inside of my tire and the wheel well. I could probably get away with a 295 but just haven't tried yet.
Old 02-05-2018, 02:38 PM   #9
SCOTI
SCOTI's Avatar
245/45-20 = 28.68 tall. On an 8" wheel you would be @ 1.07" of tire per inch of width.
295/40-20 = 29.29" tall. On a 9.5" wheel you would be @ 1.10" of tire per inch of width.
Spot on.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2018, 07:07 PM   #10
75C10
Nobody has mentioned back spacing and that will be critical for wheel tire fit.
75C10 is offline   Reply With Quote
Old 02-05-2018, 07:53 PM   #11
SCOTI
SCOTI's Avatar
With those wheel sizes on a square w/a mild drop I would recommend 4.5"bs front & rear.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2018, 08:09 PM   #12
rickit
rickit's Avatar
I have riddler wheels don't rember back space ,I think they only come one way, have 8.5 on front and 10,s on back, I have 2.5 drop spindles and 1 inch springs rear leafs are flipped I first put 245 45 r20 on front and 295 45 r20 on rear in first pic, I changed tires today went with 275 45 r20 on front and305 50 r20 on rear in second pic hope this helps, I to was confused on tire size but I got the combo I was wanting now
rickit is offline   Reply With Quote
Old 02-05-2018, 08:21 PM   #13
Roaddogg
Thumbs up Re: Ordered new wheels now trying to get an idea of tire size
That combo in the second pic looks nice
Roaddogg is offline   Reply With Quote
Old 02-06-2018, 07:23 PM   #14
808_67C10
808_67C10's Avatar
Thank you so much!! The pics help greatly! All the wheel threads should say - wheel and tire combo so, people post wheel size along with the tires that are in the pic. It helps people see that it will look like too... because that matters as much as fit... if you didnt care how it looked, you would have a Prius.
Thanks again. I personally like the first pic... why did you go taller?
Old 02-07-2018, 12:10 AM   #15
brady01
255/40/20 fronts on 20x8 and 315/35/20 rears on 20x10s. Flipped rear and 2.5 inch spindles with 2 in springs. No rubbing anywhere. Pull my 18ft ranger bass boat with it too.
brady01 is offline   Reply With Quote
Old 02-07-2018, 09:25 AM   #16
rickit
rickit's Avatar
I always have liked a little bit of sidewall the 245,s just seemed to short with the stance of the truck to me, I plan on raising the rear about one inch or droping the front one inch to give it a little rake
Old 02-08-2018, 11:00 AM   #17
808_67C10
808_67C10's Avatar
Good looking truck! I really like the color combo! Thanks for the info.
Old 02-08-2018, 11:31 AM   #18
brady01
Thank you!
Old 02-08-2018, 11:43 AM   #19
808_67C10
808_67C10's Avatar
So, in the end, I purchased U111 Rambler wheels 20x8 with 245/40 and 20x9.5 with 275/40 Nitto tires. Shipping to Hawaii is a little more but it came to 2k total (with shipping, mounting & balancing, and a new set of lug nuts). All in all not to bad. should be here in about 2 weeks. I got them from SoCal Custom Wheels and their customer service was AWESOME... they worked with me and found reasonable shipping options to Hawaii - not many vendors are willing to go that extra mile.
Just as a teaser - I ordered a FITech EFI set up for it! That should be fun!
I will throw some pics up when I get the wheels here and on my Square (haven't named her yet - thats why I havent done a build thread).
Old 06-02-2018, 03:15 PM   #20
44boggers
What backspacing are you running on the front and rear?
Paul
44boggers is offline   Reply With Quote
