Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-31-2016, 05:18 PM   #1
NJM73
NJM73's Avatar
Turn signal lamp help
I am have trouble getting my turn signals to work as well as the marker lights on the driver sode of my truck. Truck is a 71 k10 suburban with ididit column and lmc headlight harness. I have all functioning lights on the passenger side (except turn signals), as well as brake lights. Headlight switch is only 2 years old as well as hi low switch. Headlight switch sends good power to the column harness so i know its not either of those. Both my flashers are good. I still have fully funtional hazard lights on all sides. When i use the turn signal lever I get a solid light on the fender marker and nothing on the bumper parklight. Bulbs are all good, fuses are all good. Just cleaned up the connectors at the firewall as well. All the wiring is original and in good shape and everything worked fine before I did the column swap. The truck sat for awhile as I was fixing and upgrading various suspension components. Please let me know if you have any ideas to wires or grounds I could check. To me it almost acts like the turn signal/parklight power is reversed but no wires have changed and everything checks out in the new column wiring harness
Thanks in advance
'71 chevy suburban -all purpose rig- in progress
'93 cherokee -dd- mild wheeler
'65 chevy c30 c&c 12' flatbed -farm truck - future tow rig
NJM73 is offline   Reply With Quote
Old 01-01-2017, 09:28 PM   #2
NJM73
NJM73's Avatar
Re: Turn signal lamp help
UPDATE I got all my marlers working, parklamp housing and socket weren't grounding out, all lights work now but still no turn signals. Gonna try replacing the flasher again tomorrow
Old 01-07-2017, 03:15 PM   #3
av8rdad
I'm having a similar problem with my 72 C10. All the lights work fine. Flashers, turn signals, headlamps all work as required with one exception: When the headlights or parking lights are on, the turn signals don't blink--they just stay on. Already changed the headlight switch--no change. Any suggestions out there?
av8rdad is offline   Reply With Quote
Old 01-07-2017, 07:50 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Try reading this for help, and check the grounds real good.
http://67-72chevytrucks.com/vboard/s...d.php?t=644387
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-07-2017, 07:56 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
sounds like poor grounds on one or more of the turn signal sockets.
VetteVet
Old 01-07-2017, 08:53 PM   #6
NJM73
NJM73's Avatar
Found my problem, some dirty grounds were interfering woth my markers. My signals didnt work because I didn't have the key turned on. So make sure you're key is on. Go figure
Old 01-08-2017, 12:29 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Happens to the everybody.
Thanks for the feedback.
VetteVet
