Old 07-13-2018, 11:11 AM   #1
72Blazerod
72Blazerod's Avatar
Truck and Van Steering Columns the same?
I am wondering if an 80's pu truck steering column would fit into an 80's Chevy van? Are they the same?
1987 GMC Suburban 1/2 ton 4x4 (Beater)
1998 GMC Suburban 2500 4x4
1972 Olds 442 Convertible
2006 GMC 2500 Duramax Crew Cab (Sold)
1972 Blazer 4x4 (Sold)
72Blazerod is offline   Reply With Quote
Old 07-13-2018, 03:29 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Truck and Van Steering Columns the same?
They are not the same.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-14-2018, 04:03 PM   #3
Pontiac1976
Pontiac1976's Avatar
As hatzie said. I think the vans are longer then the trucks then wiring floor seals just to start.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-14-2018, 09:45 PM   #4
hatzie
Moderator
hatzie's Avatar
The G series had the ignition in the dash at least through 79.
I'd be willing to bet the harmonica plug and other switches are the same connectors but the column is a different length and mounting angle.
