Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-21-2015, 08:24 PM   #1
leftybass209
leftybass209's Avatar
Which is bad, Fuel gauge or resistor?
I thought my fuel gauge was functioning properly as I had about a quarter tank, and it read a quarter tank. After I filled it past 3/4 I noticed the fuel gauge still read 1/4 tank.
I verified the sender is correct, reading 1.5 ohms empty, and about 92 ohms full.
When I operate the sender by hand, the fuel gauge will go to empty with the float, but will only stop at 1/4 tank when the sender reaches roughly 20-23 ohms.
Wiring and grounds are all great!
I have the fault isolated to the gauge, or the resistor on the back of the gauge, but I'm uncertain how to check which it could be.
The gauge will read empty when the terminal is grounded, but only reads to about 1:30- 2 o'clock position with the wire unattached.
Any ideas where to go from here?
leftybass209 is offline   Reply With Quote
Old 09-22-2015, 07:00 PM   #2
leftybass209
Re: Which is bad, Fuel gauge or resistor?
After finding some Ohm readings to compare the fuel gauges (I have two) I found that both my fuel gauges aren't even close to spec when measuring resistance from either left or right post to ground, with or without the resistor on the back of the gauge.
I ordered a new gauge, hoping that it will cure this issue. fingers crossed!
Old 10-06-2015, 01:06 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Very common when the resistor goes bad. It will not allow the gauge needle to move past 1/4 tank.
When you take the resistor off, the ohm reading across the resistor should be somewhere around 100 ohms give or take a few.
If you have bought a new aftermarket gauge, it will have a built in resistor and there is no need for the external one.
If you need a resistor for your OE fuel gauge, send me your address on a PM and I will drop one in the mail for you.
Curious to see how this turns out.
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
Also see my facebook page, classic gauge and cluster.
TBONE1964 is offline   Reply With Quote
Old 04-26-2018, 10:14 AM   #4
67-72lover
[quote=leftybass209;7317138]After finding some Ohm readings to compare the fuel gauges (I have two) I found that both my fuel gauges aren't even close to spec when measuring resistance from either left or right post to ground, with or without the resistor on the back of the gauge.
I ordered a new gauge, hoping that it will cure this issue. fingers crossed! [/quote
67-72lover is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
