Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-13-2017, 10:56 PM   #1
YoungPup1977
1972 blazer frame off project
Just wanted to post my next project which is a 1972 Blazer 4x4 frame off. Here it starts....
YoungPup1977 is offline   Reply With Quote
Old 04-14-2017, 08:47 PM   #2
YoungPup1977
Re: 1972 blazer frame off project
Progress on blazer....some body work and 700r4 rebuild...motor is on the stand...ZZ4.
Old 04-14-2017, 09:12 PM   #3
YoungPup1977
frame mock up with 700r4 transmission moving engine forward using the stock location of the Transfer case to reuse driveshaft original locations (no cutting of driveshafts) along with stock linkage being installed. Oh yea, used the advance adapter output shaft in the 700r4.
Old 04-19-2017, 10:02 AM   #4
72 paul
How close is your front driveshaft to trans pan, modifications there,any problems?Doing same. Trans is back home from build in couple days,double cardan may get in my way,ready to mock mine up as well. Thanks for any replies or moe pics.
72 paul is offline   Reply With Quote
Old 04-19-2017, 04:57 PM   #5
YoungPup1977
By using a stock pan, it will work ok. Not alot of clearance but I do not have to beat in the corner of the pan. With the driveshaft moving up and down will not hit the stock pan in any way....
Old 04-19-2017, 05:23 PM   #6
72 paul
Knew the reg pan would work but was curious if you mighta had to whack it on that corner or modify, Ill find out on my deal in a about week.Thanks,have fun.Paul.
Old 05-08-2017, 10:14 PM   #7
YoungPup1977
Stock trans pan works, no whacking or mods required. Thanks.
Old 06-20-2017, 11:06 PM   #8
YoungPup1977
Trans linkage for the 700R4
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
