Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 05-07-2017, 09:30 AM   #1
Sixball
Heater Core Outlets. Which is Which ?
I just put a 454 in my 94 GMC Sierra 1500. I didn't hook the heater core outlets up because I didn't have any hose on hand at the time. Now I have the hose, but I didn't know which line went where and if it mattered?
So passenger side goes to?
And drivers side goes to?
Thanks, I'm finally working out the small electrical gremlins from ditching the TBI and going carb.
Sixball is offline   Reply With Quote
Old 05-07-2017, 09:43 AM   #2
speedygonzales
speedygonzales's Avatar
Re: Heater Core Outlets. Which is Which ?
Mine has the same core but different engine.
Passenger side outlet connects to the water pump
Driver side outlet connects to the block
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 05-07-2017, 10:18 AM   #3
Sixball
Old 05-07-2017, 06:35 PM   #4
Sixball
Originally Posted by Sixball View Post
I looked at my old radiator and one hose went to the radiator. The new radiator has the same hose barb.
My aftermarket intake has a spot for one hose, and the radiator has the barb.
So, which one goes to the radiator? And what one goes to the intake?
Old 05-08-2017, 11:28 PM   #5
GM-power
GM-power's Avatar
This is how I had my big block setup in a 88 I had. Hope this helps you some.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 05-09-2017, 06:25 AM   #6
speedygonzales
Don't see it connecting to the block and the radiator. There wouldn't be enough flow in that case. Never saw one hooked up that way before.
Are you sure you're not confusing either a transmission cooler line or an oil cooler line to the radiator?
If a radiator has a cooler built in, it will have two ports one on top and a lower one.
Mine has 2 coolers, engine oil on one side and tranny on the other. I'll put money on you're confusing an oil cooler line.
Pride and joy
Old 05-09-2017, 07:50 AM   #7
95 S_Trucker
95 S_Trucker's Avatar
Some of the 88-94 trucks had one of the heater hoses going to the radiator.
If you buy any kind of factory replacement radiator, you will find a 5/8" barb sticking out of the radiator(between the rad cap and the upper fitting for the trans oil cooler. They supply a cap if you don't use the fitting on the radiator.
If the old one was at the radiator, that's where I would put the new one.
-99 K2500 LS CCSB 7.4
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable, 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 05-09-2017, 08:34 AM   #8
Sixball
From memory my pump doesn't have that other outlet (unless it is plugged) I do have the little short hose connected just like your picture though.
So the donor truck wasn't running that second water pump hose off of it.
Old 05-09-2017, 08:40 AM   #9
Sixball
My GMC with the 350 I took out had a tranny cooler. I yanked it. I also yanked the stock radiator. The stock radiator has two tranny line conections, bottom big hose, top big hose, overflow, and the barb right below the overflow that is in question.
My aftermarket 4 core aluminum radiator has the exact same outlets in the exact same spots as outlined above.
I took pictures before the swap, but I was more concerned with electrical, so the hoses didn't get documented. UUUGGGHHHH !
Old 05-09-2017, 08:44 AM   #10
Sixball
That's what I'm trying to figure out. I remember taking them off. They were hard lines at the core, then rubber. BUT, I had factory air too, so I am confused with the hoses I took off (and now long gone in the trash) Does anyone have an underhood shot of a 94 ? Showing where the heater core lines go?
As I said in an above post, I had a separate factory tranny cooler I took out during the swap
Copyright ©2000 - 2018, vBulletin Solutions Inc.
