Old 05-07-2017, 10:57 PM   #1
YoungPup1977
YoungPup1977's Avatar
1972 Blazer 4x4 to 2WD Conversion
I am in the process of converting a 1972 Blazer 4x4 to a 2wd. My question I have is related to the rear suspension regarding the shock cross member. Does anyone sell this cross member along with the trailing arm cross member. As far as I know, the c10 pickup shock cross member made by CPP will not work on a 1972 blazer frame, also I do not think the trailing arm cross member from a c10 will fit the blazer frame either....Any direction or advice would be great. Thanks.
YoungPup1977 is offline   Reply With Quote
Old 05-14-2017, 02:39 PM   #2
c10-72 II
Active Member
c10-72 II's Avatar
Re: 1972 Blazer 4x4 to 2WD Conversion
Wasted Income did a 2wd conversion using Porterbuilt stuff. Project Family Truckster is his build thread. If you don't have the money to go that route try a axle flip kit by Belltech, it's a six inch drop. I was use going that on my 74 k5 but decided to stay 4wd.
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
c10-72 II is offline   Reply With Quote
Old 05-29-2017, 10:17 AM   #3
YoungPup1977
Starting the process....4x4 to 2wd conversion on my 1972 blazer.
Removing the leaf springs and clean up the frame.
Old 12-10-2017, 01:08 AM   #4
bnii
Any updates? I bought a 70 k5 4x4 and I'm about to start a 2wd conversion. I bought a 2wd front frame section and transmission cross member. I know I will need to drill new holes for the front cross member and plan on doing a flip kit for the rear end. Did you run into any snags?
bnii is offline   Reply With Quote
Old 12-10-2017, 01:35 AM   #5
dec010974
dec010974's Avatar
Keep us posted. This thread seems like it would offer a lot of useful information.
dec010974 is offline   Reply With Quote
Old 01-21-2018, 12:40 AM   #6
YoungPup1977
Update: Installing the front cross member from a 1973 chevy pickup and found trailing arms / rear diff to add to this project. Addition of a 496 Big Block and a 700R4. I am done rebuilding the transmission, block is at the machine shop.
I know every one seems to be alarmed with a 700R4 behind a big block, I build transmissions for a living so I guess its not a big deal to me plus I do not beat on my trucks to break them....drive them to enjoy not to destroy !!!!
Bought the Porterbuilt trailing arm tubular cross member. not in pic....
Going to Fab in rear spring frame supports, pics will be coming soon........
Old 01-23-2018, 02:01 PM   #7
PEDROSKI
PEDROSKI's Avatar
Have you seen this kit?
https://www.azproperformance.com/Dea...Notch-4wd.html
72 2wd k5 blazer
86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE
Old 01-27-2018, 01:20 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
I did a trailing arm conversion a few years back (maybe 10). If I was doing it now, I would definitely use the Deadend Garage pieces
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass
gringoloco is offline   Reply With Quote
Old 02-25-2018, 11:40 PM   #9
YoungPup1977
Originally Posted by PEDROSKI View Post
Yes, I have seen this kit, I like it. Going to purchase this kit. Thanks for the info.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
