Old 05-14-2017, 02:53 PM   #1
59chevy310p
1958 GMC 336 tranny match up
Long story short got a 1958 GMC with the factory Pontiac 336 and I'm gonna be converting it to 4x4 trying to figure what tranny will bolt up to it so I can run four wheel drive. Didn't know if a turbo 350 will bolt right up. Anyone have some advice?
59chevy310p is offline   Reply With Quote
Old 05-14-2017, 09:21 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1958 GMC 336 tranny match up
Different pattern you would need something like this
http://www.wilcap.com/pontiac.html
Old 05-14-2017, 09:59 PM   #3
Port&PolishMan
Port&PolishMan's Avatar
This Site does the Trans Swaps & Many Transmission Adapter Plates ..
You have to Dig around , but it's all there ..
https://www.novak-adapt.com/catalog/...er-case-parts/
Port&PolishMan is offline   Reply With Quote
Old 05-14-2017, 10:08 PM   #4
1project2many
The Wilcap parts look complete and reliable. The flywheel spacer is an important part of installing an adapter. Couldn't find anything on the Novak page.
1project2many is offline   Reply With Quote
Old 05-14-2017, 10:39 PM   #5
Port&PolishMan
[QUOTE=1project2many;7942793]The Wilcap parts look complete and reliable. The flywheel spacer is an important part of installing an adapter. Couldn't find anything on the Novak page.[/QUOTE
Depends on what Transfer Vase Your going to use ..
That have lots of Adapter Plates for that . .
https://www.novak-adapt.com/catalog/...o-transmission
Do You have the SM465 ?
After Cruising that Site - Their Engineering does look Better . . !
Old 05-15-2017, 12:16 AM   #6
59chevy310p
I have the stock 4 speed manual tranny in it right now. currently don't have any tranny or transfercase for the project just getting started and trying to figure out what I can use.
Old 05-15-2017, 09:00 AM   #7
1project2many
If you're OK with keeping a 4 speed the M420 is a tough transmission. The original NAPCO conversion was an add-on kit and used a divorced transfer case. Divorced transfer cases were common on trucks in the '60s and '70s and one advantage to using this style case is that you don't have to change any of the original engine or transmission configuration.
A later SM465 may bolt to the original bell housing. It does in the Chevrolets but I'm not going to promise it will work in the GMC with the Poncho engine. If you can use an SM465 then you can use a later transmission/transfer case assembly.
Many later 4X4 trucks have a wider stance which comes with with wider axles and wider spring mounts. Finding axles that fit under a TF with no modification can be a challenge. IIRC the 72-ish Dodge 1/2 ton trucks are very close. They also happen to use a divorced transfer case, the NP205, which is very tough. International and Ford trucks from the early '70s also used a divorced case but the axles may require more work to install.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
