Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 05-14-2017, 08:43 PM   #1
hotrodron
Wiper washer problems
Washer dose not work and when wiper is in intermediate it just goes an goes dose not stop in correct place how to fix
hotrodron is offline   Reply With Quote
Old 05-15-2017, 02:23 PM   #2
abig84
abig84's Avatar
Re: Wiper washer problems
i remember the early 90s trucks had a circuit board issue where solder points would come undone causing this. my truck had a similar issue and i would just smack the motor and it stopped. i know its not the proper way of fixing but i jammed a large bolt between the firewall and motor and its been that way for years with no problems.
but in other probably just needs a circuit board or entire motor assembly
abig84 is offline   Reply With Quote
Old 05-15-2017, 11:10 PM   #3
hutcholdschool
That is a very easy fix. All you need to do is pull the module out of the wiper motor and it comes off very easy with 2 or 3 torx screws then it pulls straight out. There are usually 3-4 spots with solder on the board and you will notice the solder will be cracked around the pin and those are your problem spots. You just need to heat the solder up and add a little solder to the crack. Here is a video I found on youtube that looks like it shows the steps. https://www.youtube.com/watch?v=GW9iYGYDP10
hutcholdschool is offline   Reply With Quote
Old 05-22-2017, 06:37 PM   #4
prjab95
Common issue with these trucks! Just did mine on Sunday $30 bucks advance auto & bingo! Originally mine weren't doing anything at all!
prjab95 is offline   Reply With Quote
Old 06-04-2017, 09:08 PM   #5
hotrodron
Thanks for the elp
Old 06-12-2017, 03:42 PM   #6
mountie
mountie's Avatar
In my '88 Sierra, I chased the wiper problem for years.
Instead of fixing an old problem ( take my word for it).... Buy a later model wiper motor assy. It installs exactly where the old one is.
I also had replaced the actual switch, which is in the steering column.
( FYI ) The turn signal lever/device is only an extension of the actual switch, which is inside the column. I am happy I replaced both.
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 06-13-2017, 10:27 AM   #7
88lowrider
Mine is a 88 as well and it had the early wiper motor in it, more square than the newer looking ones.
I ordered a circuit board for it and Wow on the price. I then found I was able to Upgrade my wiper motor to a 92 which is the newer stile and circuit board which was about 15 bucks cheaper if I remember right.
That solved my shut off problem.
88lowrider is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
