Old 05-10-2017, 02:09 PM   #1
napcoguy
napcoguy's Avatar
Lift kits for K30? (spring widths)
I am wanting to add about 2.5 inches to the height of my 84 K30 and I am having a problem finding a add-a-leaf/lift kit that is designed for the K30(454). I have seen pictures all over the internet of lifted K30's but I cannot seem to find a system. One issue I am having is finding springs that are 3" wide, all the kits I have noticed are 2.5" wide.
From what I have read most folks think or say they are the same width on all the 73-87's and some say there K30 has 2.5" springs while others are equipped with 3" springs.
Does anyone have any information on why some would have 2.5" while others would come with 3" springs? also if anyone has any information on a small lift that would be great.
1956 Chevy 3600 Napco
1984 Chevy K30 - 454
napcoguy is offline   Reply With Quote
Old 05-10-2017, 08:03 PM   #2
abig84
abig84's Avatar
Re: Lift kits for K30? (spring widths)
when i got my k30 i took the front lift springs off my old k5 blazer. this is going back like 7 years so dont remember the details but its possible the k30 had 3 inch springs as i had to use washers to take up the slack in the bushings
abig84 is offline   Reply With Quote
Old 05-10-2017, 09:55 PM   #3
crewcabshorty
crewcabshorty's Avatar
I just put on a set of skyjacker softride 2.5 in springs on my 85 cucv .
crewcabshorty is offline   Reply With Quote
Old 05-12-2017, 08:38 PM   #4
obijuan
Measure the spring at the center pin. 2.5". 73-87/91 square body front spring all interchange.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 05-13-2017, 03:39 AM   #5
andrewmp6
See if you have a local spring shop,They can re arch yours to the height you want or make custom ones to your taste.
Old 05-13-2017, 09:55 PM   #6
sweetk30
sweetk30's Avatar
stock front are tapered leaf design = wide/thin/wide. as said its 2.5" in the middle . so any 73-87-91 solid axle leaf setup will basicly fit in the k30 .
as to re-arch don't waste your money in my opinion . .... and you can only arch so much before you need a longer main leaf to still get the eye's to install correctly in the frame .
and tapered leafs are not ment to be re-arched so I was told buy a old timer spring guy years ago . and don't mix-match reg leafs and tapered .
if bbc in your truck go 2" or 3" tuff country HD front leafs for the big block weight .
I have 3" in my k30 with sbc but a 850lb snow plow on the front . works good and rides good even with plow off.
don't forget the special dana 60 size u-bolts needed over std 10bolt/dana 44 stuff. and longer grd-8 bolts for the 2 on the pumkin or a stud kit if you prefer .
77-k30lb
79-k30stubby
85-k30lb
85-c10sb
sweetk30 is offline   Reply With Quote
Old 05-14-2017, 09:43 PM   #7
napcoguy
napcoguy's Avatar
I measured the closest to the center today and it was 2 3/4 inches wide and went all the way to 3 1/4 inches closest to the shackle.
sweetK30, I emailed tuff country today and asked them about the HD front springs because there website was basically useless so I will post what they tell me as soon as I hear from them.
Old 05-14-2017, 10:05 PM   #8
sweetk30
sweetk30's Avatar
trust us on the 2.5" wide spring will work .
and the general rule is sbc and no real extra weight = reg spring .
and if bbc or winch bumper or plow = hd spring .
good bit of info is remove the last leaf on a hd pack and bam you have a non hd pack .
good info here also . and good vendor . http://www.offroaddesign.com/catalog.htm
as much as I have purchased over the years from them I should have stock in the company .
77-k30lb
79-k30stubby
85-k30lb
85-c10sb
Old 05-14-2017, 10:13 PM   #9
People use Dana60 front axles on 1/2 and 3/4 tons with 2 1/2" springs. And you know how the passenger side bolts up in a "fixed" position. No sliding u-bolts closer together. 2 1/2" springs work
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 05-14-2017, 10:18 PM   #10
obijuan
Pretty much k30 specific kits come with different u bolts and longer rear springs.
Old 05-15-2017, 10:10 PM   #11
I was just saying since the K/30 axle bolts up to all these other vehicles with 2 1/2" wide springs, 2 1/2" wide springs will certainly work on a K/30.
Old 05-16-2017, 07:39 AM   #12
napcoguy
napcoguy's Avatar
Well if no one has had any issues with them I will go ahead and give them a shot, is there a certain lift that has the dana 60 u-bolts?
Old 05-16-2017, 10:47 AM   #13
sweetk30
sweetk30's Avatar
I hate the quality of the lift kit supplied u-bolts from about every kit I have ever used . I don't know why they give us such cheep crap .....
I get my ubolts from these guys for mail order . http://www.ruffstuffspecialties.com/catalog/
if doing a 2-3" lift no steering correction should be required so skip a drop pitman arm or raised steering arm / or block . and the dana 60 blocks suck also . never seem to stay tight .
call the guys at ord if you want a 1 stop shop of quality parts and a kit made for the 1ton over figuring it out your self . http://www.offroaddesign.com/catalog.htm
and here is my current build up project . 3" tuff country hd fronts in a k30 . has baby tires for shop roller use for now. 454bbc/4l80-e/203-205 doubler/fisher plow frame few lbs extra on the front . and I did a 3" block in the back on 22-547 springs from light duty 3/4 ton for better ride . http://www.sdtrucksprings.com/index....20group%20%231 and firestone airbag kit for the extra when I need it.
77-k30lb
79-k30stubby
85-k30lb
85-c10sb
Old 06-16-2017, 10:34 PM   #14
Speeding Dakota
Speeding Dakota's Avatar
If you don't want to use blocks in the back, check out DIY4x Shackle Flip kit for 1 ton.
http://diy4x.com/
Speeding Dakota is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
