Old 05-18-2017, 09:26 PM   #1
AnobleL74
does A/C need a relay? ignition switch HOT to touch
When i run my A/C (classic Air) the terminal on back of my Ignition switch get very hot to touch.
I notice my a/c switch get power from what appears to be a heavy gauge wire from the fuse box.
Do A/C units need a separate Relay kit?
thanks
Allan
AnobleL74 is offline   Reply With Quote
Old 05-18-2017, 09:45 PM   #2
Clyde65
Clyde65's Avatar
Re: does A/C need a relay? ignition switch HOT to touch
Most aftermarket ac systems do have a relay. I have an Old Aitlr Products system and it has one. I also do everything I can to avoid pumping modern accessories through my trucks switches or fuse block. Headlights are an example.
Good luck!
Clyde65
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-19-2017, 10:12 AM   #3
AnobleL74
Good luck!
thanks i will see about getting a relay
Old 05-20-2017, 09:06 AM   #4
AnobleL74
I added a painless relay kit to my radiator coolant fan, this seems to have fixed my problem.
Will keep an eye on it, may add a A/C blower relay kit later, i think i can use the same painless coolant fan kit
Old 05-22-2017, 10:11 PM   #5
AnobleL74
added the relay for my A/C today , ignition switch now cool to touch. i think this is going to take care of the problem.
Old 05-22-2017, 10:18 PM   #6
Clyde65
Clyde65's Avatar
Outstanding!
Clyde65
support our troops!
Old 05-30-2017, 10:14 AM   #7
AnobleL74
added thermostat switch to radiator fan, love this , much better than 100% on
Old 05-31-2017, 10:47 PM   #8
luvbowties
luvbowties's Avatar
Wink Re: does A/C need a relay? ignition switch HOT to touch
IMO, we guys would be smart to keep a 'few' relays lying around. Standard in their build and wiring, buying a few at one time is a cheap investment, and before you know it, you are out of them and need to order more. I like to get caught up into sensible habits that we don't ever have to 'break'.
sam
luvbowties is online now   Reply With Quote
Old 06-01-2017, 09:00 AM   #9
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
Originally Posted by luvbowties View Post
... a cheap investment, ...sensible habits ...
Hasnt been a good match with my car/truck hobby.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
