Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-06-2017, 09:11 PM   #1
blazer2007
no battery.test wires with battery charger ?
Can I check hot wires on a 78 chev truck with a battery charger hooked up to the battery cables. Trying to clean up some wires but don,t want to keep taking the battery out of other truck all the time.
blazer2007 is offline   Reply With Quote
Old 05-07-2017, 07:02 AM   #2
jjzepplin
jjzepplin's Avatar
Re: no battery.test wires with battery charger ?
Sounds like a fire about to happen. Test with tester! Unless you would like to see your hard work melting.
I wish I found this site when I was 19 and bought my first 72.
It's just another big pretty scar.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
jjzepplin is offline   Reply With Quote
Old 05-07-2017, 08:04 AM   #3
Dead Parrot
Depends on the charger. If it is something like a 6 amp unit, should be fine. Just keep in mind that most battery chargers don't have very good voltage filters and at low current draw, may over volt the system a bit. Lead acid batteries are a lot better at handling voltage spikes then vehicle electronics.
Plus some of the "smart" chargers may not provide voltage if they don't see a voltage already on the circuit.
Dead Parrot is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
