Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-12-2017, 06:55 AM   #1
saxart
saxart's Avatar
Alternator + Electric Radiator Fans = Need Recommendations
Yesterday I was going to bolt up the alternator to the freshly painted brackets on my crate engine, but stopped when I realized the alternator bearings are old and dry sounding.
This truck has a busted up fan shroud, so all of this just screams to be converted to an electric fan set up with an alternator that will run it.
So, can you school me on alternators?
  • 1 wire or 3?
  • Internally regulated or externally?
  • What size output is needed for this set up?
For the electric fan set up, I'd to grab something from the local U-pull to keep the prices low and have read that the Windstar 3.8L fans can work, are there other options that are better? Any and all recommendations are appreciated.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 05-12-2017, 07:17 AM   #2
clay68c10
clay68c10's Avatar
Re: Alternator + Electric Radiator Fans = Need Recommendations
I ran a CS130 and Lincoln MK8 fan on my old 454 truck. That was when I lived in TX and it happily ran at 205, a/c on or off all summer.
I may go with an explorer dual fan setup on my current build.
I also have a CS130 on the caddy, but no room for an e-fan
Any internal regulator alt will work, and generally give better output than stock. I'd avoid a one wire, that's not the best way to go. Madelectrical.com has some good reading about this.
68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17.
68 Cadillac Sedan de Ville
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
02 E320
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-12-2017, 07:22 AM   #3
jjzepplin
jjzepplin's Avatar
Others will chime in, however, I run dual Flexalite fans. I have a 94 internal reg. Alt. But the alternator does not power the fans. They get the power from your battery. The alt. just replaces the charge. I run a dual Batt. Setup and my fans draw from the second battery. Many run a single. When I did I had a Optima Yellow top Battery. Was fine for years. I hear they can run your battery down in really hot weather but I have never experienced this. Since 2013 I have been running dual Walmart $60 deep cycle batts that have a one year warranty. So far so good. I dont drive the truck much but it starts every time and I have no worries.
Oh and I second the 3 or 4 wire.
I have had a one wire and it was fine.
But if you read up the multi wire units boost output when needed. (elec fan setup maybe)
I wish I found this site when I was 19 and bought my first 72.
It's just another big pretty scar.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
jjzepplin is offline   Reply With Quote
Old 05-12-2017, 08:32 AM   #4
1972RedNeck
1972RedNeck's Avatar
I would go with a CS130 or CS144.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 05-12-2017, 10:25 PM   #5
saxart
saxart's Avatar
Would this do the job?
https://m.summitracing.com/parts/wgl-7888-3n
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
