Old 05-14-2017, 10:00 AM   #1
saxart
saxart's Avatar
Do the "CS" style alternators fit our stock brackets?
Not really an electrical question, hence the post here.
I know the wiring is different, but will a CS144 alternator physically fit the stock brackets on a (short water-pump) 350SBC? I've read that these alternators are bigger externally than the stock alternators, but couldn't find anything about if they fit (without mods) after a search here.
Thanks!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 05-18-2017, 12:36 AM   #2
ryangreen19
Re: Do the "CS" style alternators fit our stock brackets?
I tried without any luck on a 68 c10, had to get a custom upper bracket and used a 71-72 lowee bracket to tie it to the head. i dont even think alan Grove makes a cs 144 compatible bracket. My custom upper was just a long thin 1/4" piece cut into a slight boomerang. Nothing fancy.
ryangreen19 is offline   Reply With Quote
Old 05-18-2017, 11:19 AM   #3
clay68c10
clay68c10's Avatar
CS130 will, you just have to get the right clocking. Not a 144, but I've used a couple and had good results. I did do the iceberg conversion on them just for insurance since the rear bearing is a weak point.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-18-2017, 11:46 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Do the "CS" style alternators fit our stock brackets?
Late model alternator with factory brackets.
Also a factory truck bracket setup on a 64 SS Impala motor with a 94 amp alternator..
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-18-2017, 10:46 PM   #5
saxart
saxart's Avatar
Originally Posted by firedemon View Post
not trying to knock you but why all the trouble a 12 si is high amp and fit right in
12si - 94amp Max
CS130 - 140amps
Old 05-19-2017, 06:41 AM   #6
Andy4639
Old member
Andy4639's Avatar
Unless you have some need for the higher amp alternator there is really no need for it. If you have a high power stereo competition system then yea but for most trucks the 94 amp is more than enough. They bolt right in and if you buy the right one it hooks up just like the factory one.
I have done several of these upgraded alternators and re do the wiring so they look pretty much factory.
Old 05-19-2017, 10:53 AM   #7
davepl
davepl's Avatar
I'm a big fan of the 12SI as well (321-266). It does max out at 94A, but that's still a lot of amps. You could weld with your headlights on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-19-2017, 11:36 AM   #8
demian5
demian5's Avatar
Yeah I have a stock 60A external regulated in my 64 impala with about 1200 watts going through the stereo. Never has given me problems.
But the Cap and the Optima may be of some assistance, along with the fact that the ignition is the only other thing requiring energy while driving...
I have a nice 1-wire that has been laying around forever cause I have not had the need to install it. Brand new alternator, a little beat up from being moved plate to place though...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-19-2017, 12:41 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Do the "CS" style alternators fit our stock brackets?
Have we been talking on the Chevy talk forum also.
In my opinion a one wire alternator isn't as good as most think. At idle it's not even putting anything back into the battery unless it's been modified even more.
Mad electric is very helpful on this subject.
Old 05-19-2017, 05:17 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Andy this thread has puzzled me since I haven't heard of any problem mounting the CS 130 or the 144 in the stock mount. The AD 244 is a different story because it is a bigger body and the mount has to be modified. You wouldn't need that one unless you were running bags and a huge amp though.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-19-2017, 10:20 PM   #11
Andy4639
Old member
Andy4639's Avatar
I can't comment on it because I haven't tried it before. I do know as you know the 94 amp works great for a truck with upgrades but not bags and high amp speakers.
Old 05-21-2017, 08:42 PM   #12
hdff
hdff's Avatar
I wish you lived closer so you could help me with mine
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 05-21-2017, 09:56 PM   #13
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Do the "CS" style alternators fit our stock brackets?
What do you need man? Between Vett and me we can talk you through it. It's pretty simple really.
Trouble with your truck lights dimming are music fading in and out? Chances are the 37 amp alternator isn't putting enough amps out to power the system.
The fix is pretty simple though.
a 95 Buick Riviera 94 amp alternator
The pictures say it all.
If you want to clean the wiring up even more just strip the tape off and run the wires straight to the alternator. Then take the old external voltage regulator out of the truck and toss it!
Old 01-07-2021, 12:02 PM   #14
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
your photo, shows 12:00 example but the 12SI on O'Riley's is clocked at 9:00. Though it is for 1985 Buick Riviera and not a 95 Buick Riviera from your post.
Edit: if I am l am looking at the stock alt correctly, the connect is at 12:00... so that is the better "fit" I am guessing?
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-07-2021, 12:23 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here’s the internally regulated alternator on a former Blazer of mine. Bolts right in and I used the plug and play adapter from AAW. Clocked at 3:00 I believe: https://www.napaonline.com/en/p/RSE2134356
Old 01-07-2021, 05:56 PM   #16
Andy4639
Old member
Andy4639's Avatar
The 10 years difference in year model is what is wrong. GM changes things in 10 years. If you get the 95 it will bolt right in.
Old 01-08-2021, 02:11 PM   #17
hdff
hdff's Avatar
I just swapped to this one 2weeks ago. worked great with my stock bigblock brackets. Was Clocked correct, 105 amp. Had to get a different plug with a resistor and bypass the regulator. Off of a 89 Pontiac safari.
Keith
"Wanda"
