Old 01-18-2018, 03:06 PM   #1
Justin Jones
Aftermarket A/C units/kits
I searched for best kits and some older threads came up from 2009. I was looking for more recent info on what's worked for you.
We are working with someone that's a dealer for Classic Auto Air. But we are looking to try to use a "factory looking" switch panel. I know a couple of the companies will offer to rebuild the switch panel too. If we need to we will buy a factory looking A/C switch panel that came in factory A/C trucks. Ours is a non A/C truck.
Thanks.
Justin Jones is offline   Reply With Quote
Old 01-18-2018, 03:29 PM   #2
JMC1965
JMC1965's Avatar
Re: Aftermarket A/C units/kits
I did the Classic Auto Air...kind of wished I had kept the original control unit; however, the unit itself has been incredible (2 months in)
I do like the modern servo-based units
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline   Reply With Quote
Old 01-18-2018, 03:38 PM   #3
Justin Jones
Thanks. I just think with the look we're going for it would work better to have an original looking switch panel with a top of the line aftermarket unit behind the dash.
Old 01-18-2018, 03:56 PM   #4
NoNeck
NoNeck's Avatar
Justin, we went with the Vintage Air SureFit kit specifically built for '67-72 C-10s. You can get the kit for either a factory air conditioned dash or to convert a non-air dash over.
The cool thing about the Vintage Air Kit is that you can use the factory control module. It comes with instructions to modify the factory levers to be operated by the computer ECM from the unit. It's pretty slick!
Let me know if you need more info. Here are a couple of pics of our install.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 01-18-2018, 05:35 PM   #5
reeltales
reeltales's Avatar
was the install on a original a/c cab? or did you cut in your center vent?
reeltales is offline   Reply With Quote
Old 01-18-2018, 06:13 PM   #6
ElKotze
ElKotze's Avatar
I'm in the same boat. I'm restoring my '72 Cheyenne Super and I'm going with the Vintage Air unit. Little more $$, but looks very clean and easy install.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 01-18-2018, 07:15 PM   #7
Kennuck
Kennuck's Avatar
I put Vintage Air in my non AC truck, I cut in the vents holes and used original equipment AC vents and control. The Vintage Air kit integrates very well.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-18-2018, 07:40 PM   #8
Justin Jones
Nice installs gentlemen! It looks like Vintage Air might be the way to go.
Old 01-18-2018, 08:55 PM   #9
NoNeck
NoNeck's Avatar
Ours was installed in an AC cab and when you order the kit you need to specify AC or non AC cab. The factory AC kit uses some of your existing ductwork. The Non AC kit has some different components in it.
By the way, the factory control unit when modified doesn't use the original fan switch.
POP
Old 01-18-2018, 10:12 PM   #10
Dagobah
POP
Our cab is non a/c. I would prefer to not cut holes in the dash for vents. Does the kit you're recommending require doing this? I thought I would include a pic of the oem a/c control panel for you or anyone else interested in the thread:
https://www.classicparts.com/1967-72...tinfo/68-483/#
Here's a better pic:
https://www.vintageair.com/images/49767-LCE.jpg
I'd never even seen one of these til yesterday, and it's pretty neat that the letters match those in the dash...
Dagobah is offline   Reply With Quote
Old 01-19-2018, 10:52 AM   #11
BugzC10
BugzC10's Avatar
Yes..you have to cut the center and two side vent holes. Template is provided.
Check with them...they may have an under dash vent system.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-19-2018, 12:27 PM   #12
Justin Jones
I've seen a kit or two that have an option for in dash vents or under dash vents but can't remember what company they are.
Old 01-19-2018, 12:58 PM   #13
SIXTY9
Look at OLD AIR products it has under dash vents and not sure if you have to use their controller.
https://www.oldairproducts.com/produ...112508-c112541
SIXTY9 is offline   Reply With Quote
Old 01-19-2018, 04:58 PM   #14
MidLifer
MidLifer's Avatar
+1 for Vintage Air Gen IV SureFit. Cutting the dash isn't hard at all and the vents look great once installed. Just got the truck back on the road late fall so can't speak for how well the A/C works but the heat is awesome!
MidLifer is offline   Reply With Quote
Old 01-20-2018, 01:01 PM   #15
dennislbrooks
dennislbrooks's Avatar
I have old air from Ft Worth. It used the existing non ac heater controls. I did cut side holes but did not cut the center. I used an under dash center for a while but did not like the cluttered look so my center hoses just point down out of site in the center. I have no preference over old air or vintage.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 02-20-2018, 09:58 PM   #16
Z10
Z10's Avatar
Using Vintage Air. Here's some pics of my install.
You can see more on my build thread. Link below.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-20-2018, 10:01 PM   #17
Z10
Z10's Avatar
Maybe a better pic
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-21-2018, 01:31 AM   #18
Justin Jones
Thanks for the responses guys. I'm sure we're going with a Vintage Air kit as we like the original looking A/C and heat panel. We just haven't figured out what we're going to do with the vents yet.
