Old 09-27-2020, 06:01 PM   #1
msg
Distributor connector - clean the contacts or leave alone?
Cleaning up this distributor to put on a new engine and thought to clean the metal tabs in the connector but dont want to screw things up. Is there a simple way to remove them and clean them and pop them back in or should I leave it be?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 09-28-2020, 01:05 AM   #2
vince1
Re: Distributor connector - clean the contacts or leave alone?
I'd use anything from CLR followed by a good water flush to electrical contact cleaner to coating it up with a silicone dielectric grease. Contact would still be made despite the grease and it would be protected from further corrosion.
vince1 is offline   Reply With Quote
Old 09-28-2020, 08:52 AM   #3
msg
Hey Vince and thanks for the tip! I was wondering though if I should attempt to pop out the connectors from that black plastic housing and clean each separately. Not sure if its necessary but seemed like the best way to get it cleaned.
Old 09-28-2020, 10:53 AM   #4
msg
I saw this video and followed it and it turned out pretty good.
https://www.youtube.com/watch?v=xkw_52rFHU8
I just left the connector as is and dunked it in the vinegar/salt solution and then used the smaller pipe cleaner from the cleaning kit I have for the airgun and then dunked it in the water/baking soda solution and coated with dielectric grease. Onto the next deal now.
Old 09-28-2020, 12:19 PM   #5
ron350
ron350's Avatar
If that were mine I would have sprayed it with Deoxit and left it alone.
Now you don’t know if that Vinegar and Salt solution wicked up under the wire’s insulation.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 09-28-2020, 01:07 PM   #6
msg
Just like me to leap and then look. Well the guy in the video did the dunk in the water/baking soda bath to neutralize the vinegar/salt which I did do but thats water in the wiring jacket now. Dang.
Old 09-30-2020, 11:52 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
This is where your wife's hair drier comes in handy.
Old 09-30-2020, 12:39 PM   #8
ron350
ron350's Avatar
I don’t think baking soda neutralizes salt.
Good luck.
Old 09-30-2020, 02:21 PM   #9
Warrens69GMC
Warrens69GMC's Avatar
If i was to use anything it would be a nail file (cardboard) and just touch up the contacts.
blow dry clean and die electric grease the contacts .
1969 307, t350
1950 Chevy Wagon
1978 Big 10
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
