10-22-2014, 11:29 AM | #26 | ||
Re: Do you really need to move the gas tank for safety?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
10-22-2014, 11:32 AM | #27 |
For those of you interested in helping defend against fuel fires, a good place to start is removing the rubber fuel line from pump to carb. It's the "oh I just put that on there to get it running, but haven't changed it in 3 years hose"! too soon perhaps?
10-22-2014, 11:49 AM | #28 | |
1969 Chevy C10 2wd stepside longbox |
10-22-2014, 11:51 AM | #29 |
I think THIS guy had the right idea !!! . . . . |
10-22-2014, 12:04 PM | #30 | |
I was not able to find any documentation of '67-'72 Chevy pickup vehicle fires attributable to fuel tank location at the National Highway Traffic Safety Adminstration site.
When I did my analysis of the square body fuel tank location I used NHTSA's data of 1800 fire related deaths across 500 billion accumulated miles during the square body lifecycle. The net result was that you were twice as likely to win the lottery, 14 times more likely to die in a plane crash and 370 times more likely to be hit by lightning (the standard by which these types of discussions are judged) than to die in a fire in a squarebody pickup. When reviewing this information with my daughter, as a sense check, she wisely observed that (because of the "slip and fall" statistic) you are safer riding in a pickup truck than you are walking. K Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-23-2014 at 07:30 AM. |
10-22-2014, 12:06 PM | #31 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-22-2014, 12:13 PM | #32 |
I don't see a safety issue. You can argue that the fumes are unpleasant, but a properly sealed tank won't release any inside the cab. Took me a while to get that completely squared away.
Otherwise, its personal choice. I decided not to move the tank, I actually installed a new tank in the stock location to replace the old cruddy and leaking one. I didn't want to have to deal with the hole in the side of the cab or figuring out where to put the filler. I also solved the leaking gas cap issue, so even completely full in a hard right turn I get no leakage. I personally like the vintage feel, and I love watching the attendant look for the gas cap all over the truck (full service only in NJ).
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
10-22-2014, 01:51 PM | #33 |
Only if your name is Ralph Nader... and you feel Unsafe at Any Speed.
I think one of the fears of the side filler was that in case of a roll over the filler cap and neck could be ripped off, then gas spilling, then a fire.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
10-22-2014, 02:02 PM | #34 | |
The biggest problem with the tank behind the seat is when the hoses or tank seal begin leaking. But that's not a reason to relocate the tank. |
10-22-2014, 02:05 PM | #35 | |
10-22-2014, 07:13 PM | #36 |
I just love all the room I have now. Four 12" subs will be at home there now. 35 gallon tank will not be filled up much and helps keep the butt to the ground.
Pro's and Con's to everything I guess.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-22-2014, 08:18 PM | #37 |
Active Member
Do you need to move it? From reading all the posts it's more of a mental thing than a safety issue.
Here's what I deduced. -If you feel safer with it in the back then move it. -Do you want room for tools and speakers, move it. -If you don't like the smell of fuel on occasion when the cap vents, move it. -Is it a safety issue, no. -Is money and labor of moving it an issue, leave it as is. -Do you want the truck to be as original as possible, leave it where it is.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
10-22-2014, 08:38 PM | #38 |
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
10-22-2014, 08:52 PM | #39 |
I remember seeing a 60 Minutes episode where they were talking about our trucks gas tanks, they showed it rolling on the side, knocking the cap off and exploding. GM sued them because it turned out 60 Minutes tried to get the truck to burst into flames several times and finally resorted to using a small rocket motor attacked to the filler neck to ignite the gas. You could see it in the video.
http://smg.photobucket.com/albums/v655/aaronhero/ |
10-22-2014, 08:55 PM | #40 | |
http://en.wikipedia.org/wiki/Rear-end_collision Crown Victoria police vehicles have the gas tank in the rear. https://www.youtube.com/watch?v=UWJv_Hyu9-c |
10-22-2014, 10:16 PM | #41 | |
10-22-2014, 11:09 PM | #42 |
Keepin an eye out
I have never felt uncomfortable with the tank in the cab but I am going with an under the bed tank only for my 5.3 and future power adder.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
10-23-2014, 10:17 AM | #43 |
I am a Referee of life.
I've owned 4 of these trucks and many others. I've never owned a truck with the tank in the cab. None of the trucks I've ever owned have had the tank moved. I see it as a way to make more room and get rid of the fumes. I tend to think the fumes are the bigger reason that they moved the tank, along with more room.
The best way to avoid the issue, build a 'Burb, Blazer or Panel. They all had tanks behind the rear axle from the factory.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-23-2014, 10:37 AM | #44 |
Newbee
I personally thought, " What if?" So I moved the tank to the rear, and added seats with headrests. Now I wont be unconscious and fried, after a rear end collision. Collisions with any other surface of the truck are still terminal though.
10-23-2014, 10:58 AM | #45 |
When I had my 71, the gas gauge didn't work and I couldn't find a replacement (back in 98). I could take a corner and hear how much gas was in the tank, and I never ran out of gas. One of many advantages of leaving it in the cab.
"You gonna pull them pistols or whistle dixie ?" |
10-23-2014, 03:28 PM | #46 |
If you are in a serious accident in one of these trucks there probably isn't much in the way of safety constraints that is going to save your life. There are videos on the net that show the difference in how different older vehicles respond to collisions versus new vehicles.
Don't sweat the petty things and don't pet the sweaty things. |
10-23-2014, 05:18 PM | #47 |
When I drove my two 61's ,1/2 ton long fleet Chevy apache and a GMC 3500 flatbed the gas gauge was broken on both. I kept a wooden stick and used it as a dip stick to tell how much was in the tank. Never ran either one of those out of gas either. Had those 2 trucks plus a 66 C 60, a 67 GMC Camper cruiser and a 71 custom c 20 and was never scared about the tank in the cab. Never smelt any fumes either.
10-23-2014, 06:45 PM | #48 |
Wish I could find a decent Panel or 'Burb. Very few to be found and most are way to far rusted.
10-23-2014, 07:40 PM | #49 |
As a firefighter (We cover a part of the NYS Thruway) I've been to my share of car fires. Not one has ever been caused by an accident and not one has ever exploded. We had one where the fuel line under a BMW broke and kept reigniting. I finally went underneath and bent the line to stop it from leaking and lighting. Hollywood depicts car fires falsely like they do many things.
Jim
Thanks, Jim - 69 Short Step CST 350 AC/PB/PS - 69 Short Step 307 Man Column/PS |
10-23-2014, 07:59 PM | #50 |
Pinto, lets get with the times. Ever hear of the Jeep gas tank recall.
I have 0 concern with the tank mounted behind me in my 71', and I "The concern is that some older model Jeeps can easily burst into flames when they are hit from behind. Federal investigators determined the Jeeps' rear-mounted gas tanks can be easily punctured and investigators linked the gas tanks to dozens of deaths nationwide. That prompted government regulators to ask Chrysler to take action. Chrysler denies any safety problem at all, but it agreed to install a trailer hitch to the Jeeps to help reduce the chances of injury and death during a rear-impact crash." Either way, you should have a fire extinguisher with you at all times.
project: "my happy mess" |
Thread Tools | |
Display Modes | |
