02-01-2019, 07:43 PM | #1 |
Lowering my c1500 4/6...need front tire advice
I've got a '98 c1500 swb, 2wd with a 5.7. I'm going to install a Ride Tech, street grip 4/6 kit. My spring/summer/fall tires are the ones in the pictures and have the same size snow tires for winter (235/75r15).
Will these tires clear front and rear? Thanks... |
02-02-2019, 01:22 AM | #2 |
Re: Lowering my c1500 4/6...need front tire advice
I think they are the same size I have on my suburban and they work on mine. The front might be close but the back should tuck in. If you lower the front first and the fenders are sitting on the tires don’t worry till you get the back lowered, I usually lower the back first because of this problem when you drop that much. Just make sure you get correct shocks for the drop.
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
02-02-2019, 02:06 AM | #3 |
Thanks oldschool18,
That makes sense. I'll wait to see how it is once its sitting on the ground, lowered front and rear. As for shocks, the kit comes with fully adjustable shocks front and rear with replicators for the rear. Great kit! |
02-02-2019, 02:23 AM | #4 |
Did it come with a c-notch?
02-02-2019, 02:29 AM | #5 |
Yep...
Front: Spindles, Coils, adj shocks Rear: Flip kit, C notch, shock re locator, adj shocks |
02-02-2019, 02:34 AM | #6 |
Have you ever done a kit like this before?
02-02-2019, 03:09 AM | #7 |
they will fit, you will have to trim the "rain gutters" on the lower control arms to clear the wheels.
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana instagram - @esso_c10 @projectpawpaw |
02-02-2019, 03:15 AM | #8 |
Customization is what you want it to look like -- not what other people think it should look like |
02-02-2019, 10:43 AM | #9 |
Nice, this info is exactly what I needed. I've done similar kits like this before without having to do mods ('66c10, 71c10), none on this body style. I'm going to taper the rating guard like lip on the A arm instead of a blunt cut though. I do plan on tubular upper and lower arms this summer.
Here's my old '66 C10 and '03 S10 I did... |
02-02-2019, 10:48 AM | #10 |
Here we go...
02-02-2019, 12:20 PM | #11 |
I didn’t trim anything on my control arm, and I just wanted to ask cause that isn’t an afternoon project.
02-02-2019, 12:42 PM | #12 |
We're planning on a solid day to do the suspension. One of the bed rail supports has to be notched to clear the 3rd member. Well trim and grind where necessary.
02-02-2019, 03:34 PM | #13 |
What was the price on that, I was thinking about doing one...
1993 Chevy Silverado. 1984 Chevy Z28. 1972 Chevy Custom 10. 1965 Custom 10..FOR SALE |
02-02-2019, 05:00 PM | #14 |
Fir the Ride Tech kit, its $1500. Yes, there are cheaper kits out there. I like how their kit is built specifically to provide much better performance and ride quality without sacrificing load capacity.
I plan on continuing to haul and tow with it so it was an easy decision for me to go with their kit. I'll probably end up fabbing some overload airbag brackets to add to the truck. |
02-03-2019, 12:21 AM | #15 |
Rollin' Old Skool
I’m running 235/70/15 up front on my Tahoe with 4/6 drop. The spare with a 235/75 will fit as well, but I think it would cause issues if the fender lip wasn’t trimmed (or rolled). I also have trimmed rain gutters on my lower control arms.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
02-03-2019, 11:24 AM | #16 |
Thanks, likaroc13
I haven't trimmed or rolled my fenders yet. I know I'll have to down the road. I've got some smaller snow tires I bought for my '66 that I never used. I think they're 215/75r15's. I may just use them in the front for now. I'm also guessing that I'll end up trimming the rain gutters off my LCA's as well. Nice build BTW! |
02-03-2019, 07:08 PM | #17 | |
Rollin' Old Skool
02-03-2019, 08:59 PM | #18 |
I am planning on running my stock 15's for now. I'll save up for 20's this summer...
I tried to pull up your '66 but my phone wouldn't work. |
02-06-2019, 10:23 AM | #19 |
The tire sizes discussed are all fairly tall for a ~4" drop up front. They will fit... but @ those OD's there sure is the possibility of buzzing. The taller the combo, the more it's going to happen.
Same truck. Same drop. It's 'based' on a 4/6 drop (2" spindles; 1-coil removed from OE 6cyl coils; flip kit + shackles). It's possibly a tad lower; definitely so in the rear. With the 15" Ralleys, it ran 215/70-15 BFG's (26.8") & did not buzz the wells. The new combo recently installed is closer to the sizes you guys have discussed & it constantly buzzes (225/60-17's @ 27.6"). Spring rate up front will come into play. If running a taller combo, I would def ensure the spring rate is upped to help prevent the annoying buzzing.
02-06-2019, 11:10 PM | #20 |
Rollin' Old Skool
Everyone's experiences may be different, so I can only speak from mine personally; but I never had any "buzzing" issues with my '93 that had an approximately 5" (possibly lower) front drop with Western Chassis spindles & springs. The springs were actually trimmed just a bit because they sat more like a 4" drop. I ran a 225/70 up front with factory 15x7" mid-90's Caprice steel wheels. It had Doetsch-Tech shocks.
For the rear, I would definitely consider helper air bags if you plan to tow/haul. On the '93, I had a mini-notch that came with the drop kit. It had a flip kit with 2" drop shackle, so 8" total. I never hauled/towed anything, but it would bottom out on decent sized dips/bumps. It would've helped if I had trimmed the bed crossmember just above the "pumpkin." I ran a 255/60 rear tire on the same 15x7" Caprice steelies. Not sure if there are any differences between fleet & stepside bed pertaining to clearances. 19 by likaroc13, on Flickr My '97 Tahoe has a 4" drop up front with spindles/springs. It has a 235/70 on 15x7" Wheel Vintiques smoothie wheels with custom 4.5" backspacing. Shocks are Belltech Street Performance. I've never had any "buzzing" issues with these either, & I've been over more rough roads in this than I ever took with my '93. IMG_3595 by likaroc13, on Flickr
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) Last edited by likaroc13; 02-06-2019 at 11:15 PM. |
02-07-2019, 12:51 AM | #21 |
Hello likaroc13, nice rigs!
I appreciate your detailed info, very helpful! I'll take as much info I can from all of you, thanks. I'm guessing that the buzzing noise is the tire tread, scraping the inner fender plastic, making a buzzing sound...I've heard it myself when I did the 5/7 on an '03 S10. Easy fix though...tire was hitting the plastic screw fastener over bumps and dips in the road. Removed the fastener, no more noise. I've had my fair share of dropped trucks and know all are different. I've never lowered one of these before. I went ahead and put my 215/75r15 tires on the front so I should be just fine, we'll find out. I'm going to notch the brace under the bed to clear the pumpkin. I'll also be putting overload/helper bags on the back to haul and tow. At 4/6, I should have more than plenty clearance around everything. If I make it a 5/7, I should still be ok. FYI, this is exactly why I joined this forum. Like minded people sharing their real world experience. No BS...is so nice! |
02-09-2019, 11:51 PM | #22 |
After a long day and "suprise", 4" of snow...my buddy Eric and I lowered it. The RideTech kit is awesome. The quality and fit are great. Very well engineered too. I put the 215/75r15's on. We'll see if they rub or not.?.?.? I have to get an alignment done ASAP.
02-10-2019, 01:35 AM | #23 | |
Rollin' Old Skool
Have you tried turning the front wheels side to side yet?
02-10-2019, 01:39 AM | #24 |
It was getting super slick outside so I just drove a few miles to get home. I thought I heard some rubbing from the front but not sure if it's the wheels on the LCA's (I cut off the rain gutters on the outer area) or the tire rubbing...I'll check it out tomorrow in the daylight if the snow isn't super deep.
02-13-2019, 02:10 PM | #25 | |
