Old 05-27-2002, 08:33 PM   #1
Benrs86
Benrs86's Avatar
Cool hood latch modifications???
ok, i really want to change my hood so that it is like newer cars. i want to pull the hood button inside, then have the hood open a little and move a tab under the hood. i have a 69 gmc so now i have the big lever on the driver side hole of the grill. i dont want that there. is there anybody that has done this? what kind of car did you get the popper and latch and everything from? thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 05-27-2002, 08:45 PM   #2
Baradium
Binder Rep
Baradium's Avatar
buy a cable and run it to that latch to where it pulls it? If you want that lever completely deleted it sounds like you'll be doing some custom fabbing...
Baradium is offline   Reply With Quote
Old 05-29-2002, 01:32 PM   #3
Benrs86
Benrs86's Avatar
i dont mind doing some fabbing. i have a welder and everything else i would need. hasnt anybody already done this??
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 05-29-2002, 01:42 PM   #4
barn9
Half a bubble off!
barn9's Avatar
Someone posted a while back about a remote latch kit from J. C. Whitney, and said it did the job. There were a couple other alternatives mentioned also, but I can't remember the details. This is one of those questions where having the Search function available again is going to be a big plus in the future.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 05-29-2002, 09:51 PM   #5
Benrs86
Benrs86's Avatar
nobodys done it, huh?
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 05-29-2002, 10:31 PM   #6
70jimmy4x4
In the process.... will post pics !
This is my second atempt. One word of advice though, DO NOT remove the stock lever UNTIL you are certain the new cable pull mod is working right !! What a pain in the a** !!!!
Steve
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
