Old 09-27-2012, 12:01 AM   #1
1990v3500
1990 V3500 TBI problems
Just picked up a really clean 1990 v3500 4X4 with 454, th400, np205, 14 bolt, Dana 60. Was running great. Got it home, crawled underneath and wires were scattered all over going to the gas tanks. I got the schematic of the factory wiring, removed all the rat nest and re wired all. I now have a good selector valve and good pressure to the TBI, but no vroom vroom. I teased it with gas down the intake and it started. Had a friend try and start it and I observed no fuel coming from the injectors. I replaced the filter and rebuilt the TBI with new screens and o rings. Still no fuel. I jumped the injectors with a battery and they click. I have power at the injector connector with the key on, but no ground. Can someone please help me???
1990v3500 is offline   Reply With Quote
Old 09-27-2012, 09:42 AM   #2
Ski-me
Ski-me's Avatar
Re: 1990 V3500 TBI problems
Just a guess but how is the spray on the injectors? Is it worth installing some new ones?
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-27-2012, 12:13 PM   #3
1990v3500
When I "trick" the injectors with a battery they have a very even spray.
Old 09-27-2012, 12:19 PM   #4
Jonboy
Slots go on anything!
Sounds like maybe the fuel pump relay, or bad pump.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-27-2012, 12:41 PM   #5
1990v3500
There is no pump relay on dual tank trucks and I have good pressure up to the TBI.
Old 09-27-2012, 12:46 PM   #6
Jonboy
Seems like there is an injector fuse also. You may have inadvertantly shorted that out when you repaired the wiring. I don't think it is a big fuse- maybe a 5 amp if that. Mine is converted, so I still have the '74 fusebox. Just going off of memory.
Old 09-27-2012, 01:07 PM   #7
1990v3500
Crank fuse, yes it's good and has power to and through...
Old 09-27-2012, 02:54 PM   #8
Jonboy
You might gheck them all. I found wiring diagrams on the AutoZone website, it looks like there is an ECM A & ECM B fuse that might be culprit. I could have sworn there is an INJ fuse as well.
Old 09-27-2012, 11:02 PM   #9
1990v3500
Ugh....
