Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-20-2018, 10:46 AM   #1
4oldcars
4oldcars's Avatar
Brake Lights
I rarely drive my 71 Jimmy (1k mile/yr), but when I do I have to check for brake lights. The brake light fuse (20A) blows. Not all the time. Sometimes not for months. 2-3 times a year I have to replace the fuse. Wiring appears ok and I've removed and disassembled the tail lights. Everything appears fine.
Any idea what may cause this?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 07-20-2018, 12:07 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Brake Lights
It's quite possible that the brake wire inside the steering column has chafed the insulation off in a spot that grounds when you turn the wheel and when you apply the brakes it blows the fuse.
If it was shorted down stream from the firewall, it could be one of the turn signal wires.
Yellow or dark green, but that would open up the possibility that just operating the turn signals or using the emergency flashers would also blow the fuse.
I would disconnect the half moon connector and do a continuity check on the white wire to the column housing while turning the steering wheel. If you get a reading then you have found the short.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-22-2018, 10:16 AM   #3
4oldcars
4oldcars's Avatar
Re: Brake Lights
Thanx - I'll try that
4oldcars
Driving:
The ones I let go:
Old 07-22-2018, 11:36 AM   #4
Wrenchbender Ret
Re: Brake Lights
Check the dome light circuit also. It works off the same fuse as the stop lights.
Wrenchbender Ret is offline   Reply With Quote
Old 07-23-2018, 09:00 PM   #5
kwmech
Re: Brake Lights
Do you have a trailer plug on the back?
Old 07-24-2018, 11:42 AM   #6
4oldcars
4oldcars's Avatar
Re: Brake Lights
I do have a trailer plug and it too has a problem which I have been putting off repairing. Maybe I need to look into that.
I do have dome lights and they work fine. They were re-wired a while back.
4oldcars
Driving:
The ones I let go:
