Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 09-27-2009, 11:11 PM   #1
AusTx68
AusTx68's Avatar
68' BBC 396 Needs Rebuild
I pulled the 68' 396 out of my truck. Casting #3969854 2 bolt main.
Bore is standard size and so is the cast crank. I have the cast pistons, rods, balancer and flywheel. I pulled it when it started knocking. Tear down revealed a spun rod bearing. Crank would need to be turned .010 and maybe bore the block. I also have the fully assembled heads 148 castings.
Selling to clear the garage. WIW?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
