Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-23-2017, 08:38 PM   #1
62 bigwindow
62 bigwindow's Avatar
motor and trans swap advice
Finally getting around to swapping the factory inline 6 and 3 speed out of the suburban to a 350ci motor and looking for options on which trans to use
Also input on aftermarket motor mounts and trans cross member
Thanks guys
62 bigwindow is offline   Reply With Quote
Old 10-23-2017, 08:51 PM   #2
PGSigns
PGSigns's Avatar
Re: motor and trans swap advice
Jamie the engine is a bolt in on your mounts. As for a trans I have a 700R4 in mine with a Ron Francis lock up controller. I used one of the cross members like all the folks sell like ECE and CPP. The cross member for the manual has been removed. I had the drive shaft cut and balanced by a local shop to get the length I needed. I have the Lokar shifter in it and it looks like it came that way. With the 700 lots of folks use the TV made easy setup from Bowtie overdrives.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-23-2017, 09:07 PM   #3
lowbucktrucks
What ratio rear end do you have? It's probably a 3.73 or 4.11 since you had a 6 cyl.
I would go with a 700, especially if I intended to go on the highway. (My trucks have a 3.07, I 'm using a th350.)
If you want a manual I would probably go with an NV3500 or 4500
How are you going to drive it, and what ratio gear do you have?? Manual or auto??
lowbucktrucks is offline   Reply With Quote
Old 10-23-2017, 11:26 PM   #4
Captainfab
60-66 Nut
As long as your 6cyl is a 230/250, the small block will drop right in it it's place.
You can use a factory trans crossmember from a '63-'87 truck or Suburban.
