09-21-2017, 05:20 AM | #1 |
Can anyone post a pic of how the OEM battery clamps down?
I am finally nearing the end of my rebuild but I don't have a clue how the battery clamps down into the battery tray.
I'll be using OEM battery tray hardware, can someone hit me with a pic? |
09-21-2017, 07:24 AM | #2 |
Old member
Re: Can anyone post a pic of how the OEM battery clamps down?
Battery sits in the tray and this piece bolts it into place on motor side. It fits the lower part of the battery side.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-21-2017, 07:44 PM | #3 |
Here is the clamp installed on the battery. I thought the clamp went the other way (flipped) when I first put it in.
11-12-2017, 09:36 AM | #4 |
Is this correct?
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
11-12-2017, 09:44 AM | #5 |
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
11-12-2017, 11:10 AM | #6 |
Is this correct?
11-12-2017, 11:24 AM | #7 |
That's what I've got on both my trucks.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-12-2017, 02:09 PM | #8 |
Wow those pics are great, thanks!
What a great way to hold a battery down..........much less in the way at the top. |
11-12-2017, 02:35 PM | #9 |
Replaced the broken battery tray and now bolt doesn’t reach the nut on mine. Maybe it’s not the right bolt
Posted via Mobile Device |
