Old 03-16-2017, 07:33 PM   #1
Kim57
Kim57's Avatar
Steering column question
1957 truck.
Any one who has used a Flaming River or Ididit column what length did you use.
Is one brand better than the other? What about customer service after the sale?
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-16-2017, 08:31 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Steering column question
They are both quality columns, I didt sometimes take a while to get if its anything out of the norm. If your buy one that's in stock get the best priced one.
32 is a good length depending on if you have floor shift or column shift
30-32 works
Old 03-17-2017, 08:39 AM   #3
bowt1ed
I bought a 30" standard tilt Ididit (floor shift) for my 57 w/2nd gen subframe and IROC box. It allows a proper distance between me and the wheel, and the wheel and the dash (w/3.5" drop), and still protrudes adequately to stay within the maximum 35 degree allowable arc of the Borgeson swivel.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 03-17-2017, 09:12 AM   #4
Kim57
Kim57's Avatar
Thanks guys.
Kim
My build thread
Old 03-18-2017, 07:48 AM   #5
hogfarm
I bought an Ididit 32" column with column shift for my 58,it seemed a little to long,it got in the way of the headers.and the shift linkage,I was able to sell it to a friend.Monday i'm going to buy a 30" ididit
hogfarm is offline   Reply With Quote
Old 03-18-2017, 09:06 AM   #6
Kim57
Kim57's Avatar
Good to know.
I plan on using a floor shift and my headers are shorties so a 32 may work for me.
Kim
My build thread
Old 03-18-2017, 09:10 AM   #7
hogfarm
Kim
the 32" will work fine for you,the biggest problem I had was the shifter arm was real close to the headers,the colunm was installed and I was going to use it,but then my buddy came along and I sold it
Old 03-19-2017, 08:13 PM   #8
my56chevytruck
my56chevytruck's Avatar
Originally Posted by Kim57 View Post
1957 truck.
Kim
Hello Kim,
I've had both companies in my street rod and my truck. I put a Flaming River 32" in the truck and I have my seat as far back as I can in the cab. I also put a floor shift in my 56. Also, the Flaming River people are very helpful to talk to.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-20-2017, 08:00 AM   #9
Kim57
Kim57's Avatar
Thanks for all the reply's guys.
Kim
My build thread
Old 03-21-2017, 01:43 PM   #10
idbeast
Kim, my Ididit ordered for the 55-57 is 31" floor shift. After I got it and finally took it out of the packaging, it dawned on me I should have just gotten a column shift as when I looked at my 55 GMC 2nd gen, with a factory V8 factory GMC Truck Hydro-Matic, it would have almost looked the same overall.
Jim
idbeast is offline   Reply With Quote
