12-23-2016, 04:23 PM | #1 |
My 84 K10 project
OK, I'm going to try and do a build thread. It'll be slow, and a budget deal. This will be my daily driver, so I'm going to try and get the engine in, 700R switched to a 350 turbo as soon as I can. I have done installed new ball joints, 1 RS tie rod end, calipers, all brakes including wheel cyl, spring kit, axle bearings and seals, front wheel bearings and seals. I've put a turn signal deal in the column along with a new dimmer switch, 2 sealed beams, and I have new tail light lens with chrome along with the housings for the rear. Pics of the engine I just finished.
12-23-2016, 04:26 PM | #2 |
Re: My 84 K10 project
Try again, cross your fingers.
12-23-2016, 04:33 PM | #3 |
Having problems with pics, bear with me here, not to good at this.
12-23-2016, 04:41 PM | #4 |
Weel, finally, they're a little big, but they are right side up. I'll post a pic of the truck also, later I'll post more. The engine is a .030 over stk short block, flat tops with a Lunati voodoo cam, hyd, the 781 heads have 2.19, 1.88 stainless valves, been all gone through with new springs, retainers and a 3 angle valve job. I had all this stuff already, so I went with what I had. MSD street fire dist, Wieand intake. Stk rockers, cheap Summit valve covers.
12-23-2016, 10:19 PM | #5 |
Interior as it looks now.
12-23-2016, 11:03 PM | #6 |
I made my own center trim for the grille, turns out I had a 86 grille in my truck and I bought an 84 so when it wouldn't fit I made my own.
12-25-2016, 01:18 AM | #7 |
Anyone going to give me some comments? The Good, the Bad,the ugly? Waiting on some modivation, and insperation here,
12-27-2016, 04:44 AM | #8 |
Truck looks like a good solid start, and your engine looks very nice! Why are you swapping out the 700r4 for a th350?
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
12-27-2016, 06:35 AM | #9 |
looks like a nice start. why use a weak tranny behind a stout motor though? go th400 at least...4l80e if you can swing it.. well worth the $ my $0.02
12-27-2016, 11:30 PM | #10 |
350 will be fine. Friends building it and he done all my glides in the dragster I had and he done the 350 turbo in my chevelle, it puts out way more than this 454 ever will. The 700 would live with enough money put into it, but with 3.08's and 11.50 tires, I don't need it. It seems the interior trim is pretty brittle. Pulled the head liner out and it breaks if you look at it wrong. Got a headliner kit to recover it, dash had a cover over it, it was cracked, dash pad looks even worse. Need at least a left side armrest, and a few other things for the interior. Guess I'll have to sell my sbc tunnel ram set up to fund this project. At least get the interior all together.
12-28-2016, 01:58 PM | #11 |
I like what you did with the grill. Get some pics of it installed already...geesh.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
12-28-2016, 06:16 PM | #12 |
Cool truck. Motor looks great.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
12-28-2016, 09:23 PM | #13 |
Right now the truck looks like it does in the pic. Need to make some money.
01-08-2017, 05:30 PM | #14 |
Update time, I've been doing body work, sanding and all the fun stuff. Got to get the bed loose and back some so I can do the cab corners. Got all the interior out. Rebuilding the vent assys I managed to break the left side glass. Got to make another trip to a junk yard I found that has about 30 or more square bodies. Got to get some other stuff anyway, he has some later truck 4 spoke steering wheels he priced for $25. Found a nice step bumper for $25 a guy has, just got to go get it. Also found a spacer that my buddy had so I can get the 350 turbo in and still use my driveshafts. Here's some pics.
01-08-2017, 05:45 PM | #15 |
This is a budget deal, so I was planning on single stage urethane. What do you all think about these colors, 1st is from TCP Global, electric blue, 2nd from Summit Racing, bright blue metallic.
01-08-2017, 08:55 PM | #16 |
Holy crap, you have been busy!!! Wow and yard that has 30 squares, I would be in heaven. I might just have to take a trip down to Kentucky.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-08-2017, 08:56 PM | #17 |
Second one, Blue Metallic.
01-08-2017, 09:38 PM | #18 |
Thanks, that was my choice also. TKCR, come on down, just 1 question, can you block sand?
01-08-2017, 10:02 PM | #19 |
LOL, no but I'm sure I could learn, although it doesn't look fun.
01-08-2017, 09:42 PM | #20 |
looking good brother! like the color!
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
01-08-2017, 11:06 PM | #21 |
It's kinda like the wax on wax off.
01-08-2017, 11:20 PM | #22 |
Oh no!! I detail cars on the side to make a little extra money to support my Truck habit. Lately I've been sticking to just doing interior detailing because I hate waxing or polishing. And I even use a obital polisher, there ain't no way I would do it manually. So sorry, I guess I won't be much help block sanding.
01-09-2017, 10:55 AM | #23 |
Looks like fun! I do love a big block!
TKCR, we have a yard here that has close to 100 squares. One of these day's I'll count just out of curiosity. Every type you can imagine, no super rare parts though. Even a short step 4x4! Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
01-09-2017, 11:32 AM | #24 | |
But mainly my thing is now is salvaging bench seats to restore/recover. If there is a lot of seats, I just might have to hitch up the trailer and come down to Kentucky & North Carolina. I would be in HEAVEN!!
01-10-2017, 12:48 PM | #25 |
Here is a shot of the floor now.
