Old 01-12-2007, 11:17 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
05 Chevy- Speedo is jumpy
I have an 05 Chevy Silverado Ex-cab with a 5.3 auto and 3.73 (for reference). My service manager uses it as his daily driver so I haven't actually witnessed this happen.
He says that the speedo will jump up to 110+ mph and stay there a while then gradually settle back to normal. This has happened 2-3 times recently.
Anyone have this happen? I assume it's a speedo bad sensor, but I hate to change parts without a clue.
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-12-2007, 11:42 AM   #2
turbochevy
Re: 05 Chevy- Speedo is jumpy
Anyone?
How many miles on the truck? 05 SHOULD still be under warranty, there might even be a TSB on it.
1970 Chevy C 10 SWB
turbochevy is offline   Reply With Quote
Old 01-12-2007, 03:02 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
It has 46k on it. We put miles on quick...
Articles-
"Refining Sierra"
Old 01-12-2007, 07:59 PM   #4
turbochevy
Holy ****! well, you should still check and see if there is a TSB on it. This may be something that is software based.
1970 Chevy C 10 SWB
Old 01-12-2007, 08:06 PM   #5
>X<
registered IWATA user
>X<'s Avatar
my fuel guage jumps all day, especially on empty and full.
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 01-12-2007, 08:17 PM   #6
The Hard Way
The last time I had a speedometer up to 110 it didn't jump there, it took quite a while on the accelerator to get there. I've heard that if you wrap a rubber band around the housing of a gauge it will keep it from jumping, but that's for mechanical gauges. I wish I could help.
The Hard Way is offline   Reply With Quote
Old 01-20-2007, 08:08 PM   #7
PHAT 53
PHAT 53's Avatar
Yes there is a problem with the gauge clusters on GM cars and trucks from about 1995 and up. As far as I could tell there is no recall. I would add that the problem is not only with GM but most other cars that have electronic dashes. The fix is to have your gauge cluster rebuilt. I have a 2003 Chevy Silverado. My gas gauge just went out. Every time I turned on the key the gauge would go about a ¼ of an inch farther clockwise. My shop checked it out with their plug in computer to check codes and do diagnostic check on the truck. During the check the plug in computer cycles the gauges, my gas gauge would not cycle. But the computer said that my gas tank was 45% full of fuel. That told us that the gas gauge was bad. According to the blogs on the Internet the two most common gauges to fail are the speedometer and the gas gauge.
Now we come to the bad news. Through the Chevy dealer here in Tucson it’s about $550.00 to send the gauge cluster off a get it rebuilt. Plus about $100.00 to pull it out and reinstall it. The price was the same at the repair shop that I use. Again according to the blogs on the Internet that’s the common price everywhere.
Now for the not great news, but almost good news. As I searched the Internet for information after about 8 hours I found Tom Jeroski at Mr. Whizard Technical Services (yes I know he has an h in wizard it must be the way they spell it in Canada) www.mrwhizard.com/ Toll Free 1 888 803 8523. Tom does flat rate repairs for most electronic gauge clusters. I sent my gauge cluster Mr. Whizard with his supplied prepaid UPS label, which is covered in this flat rate price. Yes that’s right shipping is covered both ways for UPS ground. The only small problem is that it takes two weeks for the round trip. But again the good news is that the truck will run and drive with out the gauge cluster.
On the Mr. Whizard website you will find instructions on how to remove your gauge cluster. I was able to unsnap the dash trim (one piece) and pull my gauge cluster out (the cluster is held in with four 7 mm screws) and put back the dash part in under15 minutes. It was a snap to say the least. lol
The flat rate for my 2003 Chevy Silverado truck was $169.00 US. Tom lives in Canada so you will see an exchange rate thing on your credit card but it still comes down to $169.00 US. By the way Tom did both my gas gauge motor and my speedometer motor for the one flat rate charge. Tom said he likes to replaces the GM speedometer motor because they fail so often.
I put the gauge cluster in today and it works great. Saved $381.00 to 481.00 depending on whether you do the work yourself or not. Now I can go get that GPS unit I wanted.
PHAT 53
It now takes me all night to do what I used to do all night!
PHAT 53 is offline   Reply With Quote
Old 01-21-2007, 12:18 AM   #8
joerocks
same as what phat 53 wrote my 04 did the exact same thing. luckily it was around 33,000 and still under warranty, make sure they warranty there work because GM uses rebuilt clusters. and mine needed about 5 tries to get it right. as soon as they would fix it and you shut the truck off and started it again the odometer would just read error.
1992 Jeep Cherokee 4.0 AUTO
1972 C10 350/350
1971 C1500 350/350
1970 C20 396/400
joerocks is offline   Reply With Quote
Old 01-21-2007, 09:59 PM   #9
BP68
BP68's Avatar
I am a service tech at a Gm Dealer, and I have seen this problem a lot.
I cannot tell you the exact cause, but it is a fault in the cluster itself.
We do all our radio and cluster repairs thru exchange.
If you can find a place to "rebuild" like the guy in Canada, then that is prob gonna be your best bet.
Now would be a great time to upgrade to a Escalade cluster.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 01-23-2007, 08:01 PM   #10
Primed67
Primed67's Avatar
same thing happened on my 04 but it finally stuck on 110. They replaced the cluster and reprogrammed it and haven't had a problem since.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 01-30-2007, 01:01 PM   #11
Jonboy
Slots go on anything!
When it sticks, you can work it down a few MPH at a time by starting the truck and turning it off.
