Old 04-16-2010, 02:55 PM   #51
lnwlfbsktbll
lnwlfbsktbll's Avatar
Re: Project 6.0 (my '87)
Originally Posted by Evil Trailblazer SS View Post
The LY6 engine used a 190lph fuel pump, so this pump mounted in your bucket will be the best and cheapest option...
Thanks Evil... you and everybody on this board just keep impressing me with the wealth of knowledge available.
Originally Posted by Jhogan830 View Post
beautiful 6.0 man! im still rollin the 350 =/ bout to make it a stroker !
Thanks for the compliment. Good luck with the stroker project. One day mine will be rolling again.
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 04-16-2010, 03:27 PM   #52
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
We are pretty smart for dumb people! Hahaha!
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 04-18-2010, 08:37 PM   #53
lnwlfbsktbll
Has anybody tried edelbrock's ls1 shorty conversion headers?
Old 04-19-2010, 05:48 PM   #54
Evil Trailblazer SS
You be better off using the stock manifolds...nothing flows better than the stock LS2,LS3,LS7 manifolds until you go to a full long tube!
Your LY6 has LS3 manifolds...or it has them from the factory, anyway!
Old 04-19-2010, 06:02 PM   #55
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
You also need to consider what you are going to do for a fuel pressure regulator...the newer fuel systems that are one way systems use a regulator mounted in the tank after the fuel pump! Have you thought of this yet?
This part is easy. Use a 99 Vette filter/regulator. Mounts to the frame, and all he will need is a short return line back to the S/U.
lnwlfbsktbll - The ACDelco EP381 is indeed a good pump choice. For $68 you will have a quality pump that will provide 58 psi all day long.
Here's a couple part numbers for you, and I attached a .PDF of some more part numbers that should be handy for your swap:
Corvette fuel filter/regulator, WIX 33737, $34.00 ea rockauto.com
Fuel fitler adapter, 5/16", Dorman 800120, $6.30 ea rockauto.com
Fuel fitler adapter, 3/8", Dorman 800121, $6.30 ea rockauto.com
3/8" x 12" double end male, Dorman 800155, $8.00 ea rockauto.com
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-19-2010, 08:09 PM   #56
lnwlfbsktbll
Wow, thanks everybody I'm loving all this info.
Old 04-19-2010, 08:54 PM   #57
Evil Trailblazer SS
Glock's idea is perfect advice and a great solution to your problem!
Old 05-15-2010, 04:16 PM   #58
lnwlfbsktbll
Progress is slow right now, but I finally got the cab off with the help of a few friends. So here's how she sits waiting for me to strip the frame down.
Old 05-16-2010, 07:29 AM   #59
menace121978
menace121978's Avatar
nice job man. little by little!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 05-28-2010, 02:58 PM   #60
lnwlfbsktbll
Looks like I found a 6L90 locally for $1000 with a $300 core, me pulling. I might just have a tranny by next week.
Old 05-28-2010, 05:57 PM   #61
JohnC
JohnC's Avatar
Sweet!
JohnC is offline   Reply With Quote
Old 05-28-2010, 11:05 PM   #62
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Cant wait to see it going back together. Little at a time!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-01-2010, 07:48 PM   #63
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
We're doing a similar build...although my LY6 will have a carb. and a 200-4r behind it. The 6L80e would be nice though!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-01-2010, 09:34 PM   #64
lnwlfbsktbll
Do you have a build thread I can follow?
Old 06-01-2010, 10:17 PM   #65
68GMCCustom
sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=404859
Kurt -
Old 07-10-2010, 07:58 PM   #66
lnwlfbsktbll
Does anybody have some pictures or links to a picture of their motor mounts installed on their ls motor before it all went in?
Old 07-10-2010, 08:28 PM   #67
signgod2
signgod2's Avatar
You can check out my build under Project blue-ray, It will show a pic or two of what 68 short step has done with it . He took an original motor mount bracket and matched to a flat motor mount plate attached to my gen 4 motor 5.3 there. hope that helps out
signgod2 is offline   Reply With Quote
Old 07-11-2010, 03:06 PM   #68
lnwlfbsktbll
Thanks, I got some adapters and I'm having some trouble getting things to line up so I wanted something to compare to.
Old 07-25-2010, 05:42 PM   #69
lnwlfbsktbll
Ok so progress has been really slow considering something like 2 weeks straight of 14 hr days and a vacation after that, but here goes. I managed to find time to get my 6L90E and LY6 together and bolted onto my frame. I decided to skip Stripping and painting the frame because I'm on a little bit of a time crunch with my painter friend that is no longer going to be a painter in the near future. So mounting the motor and getting things back together so I can paint took priority over sorting the wiring out and such. Here are some pictures.
The motor mount adapters I bought wound up allowing me to reuse the stock Th400 crossmember and in its original location. It took a while to get things straightened out, but part of that was because the O'Reilly's I bought motor mounts from gave me the wrong part. Correct parts installed and it all went together like it was supposed to be there.
Old 07-25-2010, 06:32 PM   #70
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress! The motor/tranny looks right at home in the frame.
Old 07-25-2010, 08:19 PM   #71
68GMCCustom
thats going to be a sweet package when you get it all in.
Kurt -
Old 07-25-2010, 11:40 PM   #72
lnwlfbsktbll
Thanks for the comments. I hope it goes as smoothly as it has been so far. I haven't had any really large issues. Still can't decide between the OE style mirror or the little square repro ones like LMC carries here.
Old 07-26-2010, 08:46 AM   #73
JohnC
JohnC's Avatar
Nice progress man!
Old 07-27-2010, 04:59 PM   #74
lnwlfbsktbll
Does anybody have any reccomendations on who would be good to go through my wiring harness?
Old 07-27-2010, 06:36 PM   #75
68GMCCustom
I think I've heard good things about LT1swap.com?
Kurt -
