02-05-2010, 01:01 PM | #1 |
1970 Daily Driver
Door Wire Looms
I have power window and door lock wires going into my doors and would like to find a good wire loom. For now I black electrical taped the wires tight and put plastic sleves in the holes drilled in the door and door jam as not to have the wire insulation damaged. What are you guys using? Pictures would be great.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
02-05-2010, 05:44 PM | #2 |
1970 Daily Driver
Re: Door Wire Looms
02-05-2010, 06:01 PM | #3 |
67-72 Addicted
Re: Door Wire Looms
On our 55 Bel-Air show car we used these spring loaded contacts. You can see them in the picture; it’s the squarish black plastic piece with 4 spring loaded brass contacts. One set goes on the door and the other on the cab. It works really well but of course only when the doors are closed. (No big deal). We tried the loom style at first but they were somewhat awkward, they bound up and seemed a little rough.
'72 K20 |
02-05-2010, 06:56 PM | #4 |
That's right, it's Copper!!
Re: Door Wire Looms
I used the stainless ones from Summit. They work well!!
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
02-05-2010, 06:58 PM | #5 | |
Re: Door Wire Looms
We sell those to. The only thing I don't like about them is sometimes they will fray on you. I like using the later model stock rubber ones Last edited by mbgmike; 02-05-2010 at 06:59 PM. |
02-05-2010, 08:06 PM | #6 |
Chevy Truck Addict
Re: Door Wire Looms
I used a kit by Specialty Power Windows. Reasonably priced and "easy" to install. Also, they are wound stainless so no issues with fraying.
http://www.specialtypowerwindows.com/products.php?c=3
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . Last edited by C10-Driver; 02-05-2010 at 08:07 PM. |
02-06-2010, 11:48 PM | #7 |
1970 Daily Driver
Re: Door Wire Looms
fastom and C10-Driver can you please post installed pictures? I would greatly appreciate it!
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 02-06-2010 at 11:49 PM. |
02-23-2010, 12:25 PM | #8 |
1970 Daily Driver
Re: Door Wire Looms
Any pictures?
