Old 12-27-2013, 04:02 PM   #1
zetan
spark plugs
I need OEM correct plugs and wires.
1960 chevy k10 283 - book lists AC 44 plugs as the correct factory plugs .035 spark gap.
1 green stripe or 4 green stripes? (as found with 1960 Corvettes)
code after the AC44 - R, XLS, T etc - what is correct for the stock ignition system? Will "resistor" plugs work ok or is that only for HEI systems?
http://www.ebay.com/itm/NOS-AC-DELCO...034534?vxp=mtr
vs
http://www.summitracing.com/parts/acf-r44xls
1960 Chevy Apache K10 283ci short step
1984 GMC Rally Van 6.2L diesel
1995 Chevy G30 cargo van 6.5L turbo diesel
zetan is offline   Reply With Quote
Old 12-27-2013, 05:36 PM   #2
Wrenchbender Ret
Re: spark plugs
I like the R44S. It is a more modern plug with resister & extended tip. XLS is wide gap for electronic ign. T is the tapered seat used in about 1971 up. If you want exact as original for judging you will need the 44 but I dought if you can buy them yet.
Wrenchbender Ret is offline   Reply With Quote
Old 12-27-2013, 08:04 PM   #3
60-66
60-66's Avatar
Re: spark plugs
Are you looking for "exact" correct spark plugs ? The AC 44 is what you are looking for but there were others offered for that application. None were resistor or R44. 44 45 and 45S are the vintage plugs . The 45 is considered the slightly hotter plug and I believe the "S" stands for a more heavy duty plug. 4 Green rings all the same size are "era correct" but to be exact you need to find spark plugs DATED before 1969 as they changed the tip from serrated to smooth somewhere in that time frame. This set has the smooth tip but correct even 4 rings. http://www.ebay.com/itm/NOS-AC-44-4-...ddb6cf&vxp=mtr
This is a super early set. wish he had a closeup of the tip.http://www.ebay.com/itm/62-Corvette-...610768&vxp=mtr
You can see they command a hefty price also. Just depends on what your trying to achieve .
Jon
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-28-2013, 12:28 AM   #4
pimpston65
globetrotter65
pimpston65's Avatar
Re: spark plugs
hey, i saw this thread and did some research and found a site that has AC 43 can i use these plugs as i like the style and the AC 44 are out of stock and im not sure about hotter or colder plugs i have a 66' 283 stock cam and pistons no valve work bare bones stock, my question is will it be wrong to use 43 plugs to get the same effect or should i hunt down some 44 plugs? thks
pimpston65 is offline   Reply With Quote
Old 12-28-2013, 02:48 AM   #5
AnlaufJohn
Re: spark plugs
Zetan hasn't given an answer about the purpose for original parts.
NAPA has AC plugs, and who really cares if they are 1 stripe or 4? Or why should I start paying attention to the # of stripes? Please enlighten me. The spare set of AC plugs I just looked at don't have any stripes. See? I am not in a panic.
R45 is what I use in my 1966 C-10 283. The manual call for AC 44.
I think the R43 plug would work really well near the Equator. Or in the Middle East/Sahara Desert area.
What I use my truck for is not for show. I use my truck. I haul Lucy around when I go shopping, haul my motorcycle to the woods, pick up groceries and when I go do my laundry.
Eugene, Oregon
Lucy's Limousine
1966 C-10 LWB
283 w/ 2bbl, OE carb and dist.
4 spd (granny 1st) w/ 3.73 rear end
AnlaufJohn is offline   Reply With Quote
Old 12-28-2013, 03:56 AM   #6
pimpston65
globetrotter65
pimpston65's Avatar
Re: spark plugs
Man i hear you, on the spark plug use. im almost done with a build i stated in 98'. when i started the build i just rip'd parts out and didnt care if they were oem or not, cuz i wanted to build a lowrider/hotrod truck. Now many years later i've learned sooo much about this truck and how to get awesome oem,nos parts and for cheap. i was just looking for info as i normally do and just when i thought i had enough stuff to finish this truck. someone goes and ask about those spark plugs and me being all crack'd out i had to investigate it, thats all cuz i have plugs and wires. hell i just drop'd off one of my 5 rims to the powdercoater today. i really dont need some fancy date correct plugs, but i just wanted to learn as much as i could, plus if i were to ever sell my build i may get a bunch o' cash. anyway thanks for smacking me outta my 65 stepside SWB BBW haze. ps thks for the info on the "colder" plug. ps i never posted pics maybe when its all done i will......
Old 12-28-2013, 10:57 AM   #7
60-66
60-66's Avatar
Re: spark plugs
While I agree AnlaufJohn about ":who cares how many stripes " for a daily driver, after all no one can see the plugs hardly once installed. Autolites are another good choice IMO also. But, Zetan asked for "I need OEM correct plugs" so I thought I would look the spark plugs up in an early Chevrolet parts book . I've learned quite a bit lately about "original" production line spark plugs especially with the trucks I recently purchased. Only trying to help and shed some light on the subject when it involves the words OEM correct. I enjoy learning about this stuff myself and this forum and its members have taught me a lot about these trucks, great forum great people !!
Old 12-28-2013, 03:14 PM   #8
zetan
Re: spark plugs
Thanks for the input everyone.
We are restoring this truck as close to original as from the assembly line. No chrome, no modern upgrades. This truck will be for show or auction, not a daily driver.
This is my first ground up resto, and my previous automotive experience has been with 6.2/6.5 diesel, so I have lots of seemingly silly questions. I realize these parts aren't seen seen easily, but I wanted to pass the bozo sniff test if someone pulls the wire off to look. If I went to autozone and got NGK B6S, it might look obviously wrong. I also don't want to waste money on a NOS part if not really needed.
Regarding green stripe, I just noticed the difference while searching and wondered if it was important.
1 green stripe, 4 even stripes, 3 thin one thick...
Here are some repro 4 stripe AC 44s
http://www.ebay.com/itm/Reproduction...7eea6a&vxp=mtr
The other thing I was told was to get the 7mm spark plug wires, not the thicker ones, for the stock look.
Old 12-28-2013, 10:41 PM   #9
pimpston65
globetrotter65
pimpston65's Avatar
Re: spark plugs
I plan to sandblast the electrode and paint the rusty parts with high temp semi black and the non correct Packard wires will cover the thick green line, thanks for everyone's input. We all have our own idea for our respective builds, I'm just glad there is a site that info can be shared and for free. Enjoy your holidays
Old 12-28-2013, 11:52 PM   #10
pimpston65
globetrotter65
pimpston65's Avatar
Re: spark plugs
Here's my cheap buy
Copyright ©2000 - 2019, vBulletin Solutions Inc.
