06-27-2014, 07:38 AM | #26 |
Carpe manana
Re: Name that bolt/nut/screw size
Gravel guard uses Phillips head bolt, 1/2" nut, and a star washer as shown on this 72 example I believe is untouched since left GM
06-27-2014, 07:39 AM | #27 |
Carpe manana
Hatch handle uses tapered head Phillips head screw 1.25" long
06-27-2014, 07:42 AM | #28 |
So 1/2 nut would mean 1/4 threads IIRC?
That screw looks like it would be a #8 or #10?? Thanks for the pics!!! |
06-27-2014, 07:44 AM | #29 |
Carpe manana
Sorry not sure re: the sizes otherwise but happy to help with pics
06-27-2014, 07:51 AM | #30 |
I looked up, it would be 5/16 threads on gravel guards.
06-27-2014, 07:58 PM | #31 |
Hatch handle screw is #8-1.25"
06-27-2014, 08:34 PM | #32 |
GMCDAC
Yeah that's the "normal" standard. 1/4" bolts have a 7/16" head and nut, 3/8" bolts have a 9/16" and a 7/16 bolt has a 5/8". There are possible variations like those 12 point hood latch bolts but these are normal I.D. for buying bolts.
Instead of "tapered" those screws would be called "countersunk" I have an unmolested '70 Jimmy partially tore apart that may provide some info you are wanting on this thread. The rear seat hold down bolts are a 7/16" fine thread, as well as the seat belt bolts front, rear and the threaded holes in the roof where a shoulder harness was possible. Great thread!---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
06-27-2014, 10:08 PM | #33 |
70gmcjimmy, some of the questionable bolt size/threads have been answered. But your more then welcome to post any others. Skim thru and read all the post since it wont let me go back and edit the first posting.
06-27-2014, 10:11 PM | #34 |
screw/bolt head types.
06-27-2014, 11:48 PM | #35 | ||||
GMCDAC
DAC
06-30-2014, 11:08 AM | #36 | |
08-17-2014, 04:58 PM | #37 |
ttt
08-17-2014, 09:02 PM | #38 |
very helpful thread... will add when i can also be helpful!
11-01-2014, 12:15 PM | #39 |
Carpe manana
I'm trying to dig out the correct mount bolts for the OEM spare tire carrier to post example pics...I know I need one more (body shop lost one).
11-01-2014, 01:52 PM | #40 |
I have none of the bolts for my spare tire carrier, so I'll be waiting eagerly for this info. I appreciate you taking the time to do the research. My spare tire carrier goes to powder coat next week and I want to get the bolts done as well.
11-01-2014, 04:58 PM | #41 |
Carpe manana
Still digging - I know I have some. They are similar to these seat bolts removed from a suburban but IIRC the head was larger and not as tall, fine thread maybe 1/2"?
11-01-2014, 05:00 PM | #42 |
Carpe manana
Examples of carb stud and wing nut to attach the air cleaner to the carb
EDIT: The stud is 6 7/16" in length
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 11-01-2014 at 10:27 PM. |
11-01-2014, 05:02 PM | #43 |
Carpe manana
Rubber upper rad heater hose w part # and tower clamps (from my 72 K1500 GMC but should be same for K5) - a segment of the metal hose can be seen.
11-01-2014, 05:03 PM | #44 |
Carpe manana
Bracket to affix the power steering hoses to the frame
11-01-2014, 10:12 PM | #45 |
Spare tire bolts are 7/16-20 X 1.00 with outtie star washers. They are 5/8 socket. I broke one of mine off and going to have to tap and find another.
11-01-2014, 10:17 PM | #46 |
The screws that hold the cap onto the top of the door are #8x.50 Countersunk oval.
11-01-2014, 10:28 PM | #47 | |
Carpe manana
11-01-2014, 10:47 PM | #48 |
11-30-2014, 08:20 PM | #49 |
Can anybody post a picture of the double wall top to bed rail OEM bolts?
12-02-2014, 11:08 AM | #50 |
http://67-72chevytrucks.com/vboard/s...d.php?t=362908
This is post for body mount bolt size and length that I found. Another guy asked and I found this.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
