Old 04-18-2018, 06:27 PM   #1
studeclunker
studeclunker's Avatar
Starving out on hills
I have an old crate-350 in a '66 Camper special C-20. When I start up any kind of hill it is starving out and just about stalls out. I can back it up the hill (like a tin-lizzie) and the truck runs smoothly. Going forward (uphill) though is just not possible.
It has an electric fuel pump, works well, as far as I can tell.
I put a new mechanical Fuel pump back in and still have the same issue. Tried it with the electric and with the electric by-passed. It still does the same.
Pulled the sender/intake module from the tank and all appears to be fine. The brass fuel screen cylinder is in beautiful condition. Amazing considering its age. So there's nothing blocking the fuel supply. Would water in the tank do this? That is to say, run fine till I attempt a hill?
Found out why my fuel gauge isn't working. The ground was broken. Fixed that when I put it back together. I'll replace it with a new wire later.
So I'm stumped. Any ideas of what else to look for?
studeclunker is offline   Reply With Quote
Old 04-18-2018, 06:50 PM   #2
geezer#99
geezer#99's Avatar
Re: Starving out on hills
What carb?
Old 04-18-2018, 07:03 PM   #3
studeclunker
Newly reconditioned Rochester 4bbl.
Old 04-18-2018, 08:07 PM   #4
PGSigns
PGSigns's Avatar
Reverse is a lower gear so does not need as much power. I would be looking at the ignition and timing. All motors need fuel, fire and compression. So when looking at low power I start with compression, when all the plugs are out they can tell you a lot about what is going on in the engine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-18-2018, 08:29 PM   #5
68gmsee
Active Member
68gmsee's Avatar
You didn't mention but I'm assuming you have an automatic transmission.
If you park the truck uphill does it still act like it's starving for fuel? Maybe put it in neutral as it's trying to die out.
This would let you know if it's in fact fuel starvation or transmission related. I had a dodge van that did that on steep hills but it was transmission.
If you are certain its fuel related, lift the top of the carb off and check the float level adjustments. Also, place the fuel line going to the carb in a plastic container and check that it pumps at least a pint of gas in less than 30 seconds.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Thread Tools
Display Modes
