Old 06-30-2018, 02:02 PM   #1
plowro8
Grille care
What's the best way to remove small scratches, buff and polish an aluminum grille? There is no coating on the grille - it was either removed before or just worn off over time. Thanks!
plowro8 is offline   Reply With Quote
Old 06-30-2018, 08:34 PM   #2
yuccales
yuccales's Avatar
Re: Grille care
I use Mothers Mag Polish. Works great on my worn out old grilles.
yuccales is offline   Reply With Quote
Old 06-30-2018, 08:44 PM   #3
plowro8
Re: Grille care
What do you use the remove small scratches and gouges? Sandpaper?
Old 07-01-2018, 08:09 AM   #4
custom10nut
custom10nut's Avatar
Re: Grille care
Use the search for the thread on refurbishing your trim. There's a sequence with oven cleaner, scratch pad, sand paper, and "Ever brite" Clear coat. What I've seen it looks great and the coating is durable.
Of course it's a little work, but in the end you don't have cheap replcement trim that just doesn't compare to original
custom10nut is offline   Reply With Quote
