09-10-2018, 08:42 PM | #1 |
Do I need a high hump for a 4L60E?
Hey folks. I haven’t been on here in a while with a question but finally getting back to my project. Was wondering do I need a high hump trans tunnel to run a 4L80E and a 5.3 or will a low hump work just fine? I was thinking the trans is bulkier on the driveshaft end of the trans. Thanks
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2008 GMC Canyon (daily driver) Last edited by Bryan H; 09-10-2018 at 09:13 PM. |
09-10-2018, 09:16 PM | #2 |
Re: Do I need a high hump for a 4L60E?
I'm running a 6.2 with a 4L60E and the low hump works fine. It's tight on the top, just a couple of inches, but it fits OK. No issue with the column shifter hooking up either, I used a Lokar rod kit. Had to bend it a little, but it works excellent.
On a previous build, I had a 5.3 with a 4L60E there as well, no issues with either one. Hope this helps, and good luck!! |
09-10-2018, 09:21 PM | #3 |
Moderator
Ditto on the no need for the high hump...
Have mine installed now and no worries with clearance...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
09-10-2018, 09:44 PM | #4 |
Thanks y’all.
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2008 GMC Canyon (daily driver) |
09-11-2018, 10:58 AM | #5 |
low hump and 4l60e combo work with truck pan oil pan on a slammed truck? im about to fit the engine but heard I might need a f body oil pan.
1965 C10 long box laid out on bags instgram 65see_x .……………………….. ____ ..………________//__l \_____ ,,,,,,,/__(O)___//___/__(O)_/ |
09-11-2018, 11:01 AM | #6 |
Anything lower than 4” in the front will need the fbody pan
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-11-2018, 11:02 AM | #7 |
thanks I wasn't sure if I could raise the whole engine and tranny up or not.
09-11-2018, 04:59 PM | #8 |
Proud Vet that loves the USA
