01-06-2018, 10:09 AM | #1 |
Help with 1968 Wiring
Obviously there's a few wires here that need attention. But I'm not sure how to go about replacing them. How do they come out of that block? I dont want to damage more of them if I don't have to. Any help would be appreciated.
Matt |
01-06-2018, 01:59 PM | #2 |
Msgt USAF Ret
Re: Help with 1968 Wiring
This is the main connector between the engine wiring and the cab wiring. It is held together by a small bolt in the center of the connector that threads into the cab side behind the fuse panel. If you remove the bolt you can pull the connector apart and see the wiring terminals on the inside. The nut for the bolt is captured in plastic on the inside connector, and it can spin with the bolt if it is corroded. So use care when taking the bolt out. You might have to remove the fuse panel to access the nut.
These terminals are called Packard terminals and can be tricky to free up from the connector. They have a small leg on the terminal that is bent sideways so that it snaps into the connector to hold it in place. To remove it you have to bend the leg flat with the rest of the terminal to unlock it so you can pull it out of the connector. There's a thread on here that explains it with pictures if I can find it I will post it. The wire you are showing in the top of the connector is the resistance wire from the ignition switch to the ignition coil and the cloth covering is peeled back showing the wire. This wire is not needed if you convert to HEI ignition which a lot of member do, me included. Here is the bolt. Here is the terminal and you can see the leg that must be bent.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-06-2018, 03:40 PM | #3 |
Msgt USAF Ret
Here's the thread. Scroll down to post 13 and read through 16 for help on removing the terminal.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
01-06-2018, 05:05 PM | #4 |
Awesome. I really appreciate the info. I'll dig into. I just got the truck. I believe the previous owner installed an Electronic Ignition. So if that is the gas, I can just remove that wire?
01-06-2018, 07:05 PM | #5 | |
Msgt USAF Ret
Here is a diagram of the wiring in the stock trucks. If a previous owner has installed an HEI ignition distributor it needs a full 12 volts and you can disconnect the resistance wire. notice the starter just above the engine block where the yellow wire joins the W\orange\purple wire from the bulkhead junction.
